1 - 8 of 8 Posts
I've ridden the '06 and '07 Sprints, and while I like the bike some issues keep me from pulling the trigger. Heat issues and more upright riding position. It felt better for the riding position on the '07 but the heat issue was still an issue. Is the '08 or even the '09 better in both regards?
As a side issue, I was also wondering about the headlights and if they were better.
Thanks!
Wambo, the 07 and the 08 are pretty much the same. The Sprint really doesn't have any worse heat issues then any other faired bikes. It is a Sport tourer so understand that it leans towards sport so you will have a forward sitting position. You can change that somewhat with risers but then you can change a GSXR with risers as well.
If its to forward to you then you may need to look at something more touring and less sport.
I have an 05 and didn't like the excessive heat that cooked my buns and legs.
I had my dealer install the "heat kit" (for free).
Basically, the heat kit is some foam pads that are stuck to the inside of the fairings that seal the gaps between the engine and the fairings, which forces the hot air out of the openings in the fairings instead of directing it towards my legs. The kit also installs and a foam pad under the gas tank, which helps keep the seat moderately cool (no more roasted chestnuts on an open fire).
The '08 supposedly has improved headlights over the '07, and some harder rubber on the pegs. That's all I remember, there might be more?
I've never really notice heat problems...but then, I came from an '05 FJR, which was like riding a stove. It got so hot that the tank badges discolored! Ouch!
MP
For 2008, the Sprint ST uses new-style lenses in the headlight projectors offering an improved distribution of light and overall headlight performance.
I think the headlights are great!
headlights
That is good news, the lights on my 06 really are bad when you go into a turn. Surprises me they were actually allowed to go to market, it's just plain dangerous. I turned them up as far as I dare to try to help with the turns at night but they still are bad IMO. Still don't have a good plan but other than that I love my Sprint, best all around bike as far as I'm concerned.
1 - 8 of 8 Posts
