Hi All
I am off to buy torque wrench and some sockets to undo my front & rear wheels on a 07 Sprint. Could someone confirm the lock nut sizes in metric please(millimeters)for the front & rear wheels also how many Pounds or Newton torque should be applied to each wheel nut when tightening.
I believe the rear wheel nut is 46mm and the Newton torque should be round 140?.
Thankyou.
Hi Corky,
you need for the front wheel this tools:
- 19mm Inbus
- torque spanner (5 - 30 Nm)
- torque spanner (28 - 210 Nm)
- 14mm nut
for the rear wheel:
- 46mm nut
The torques
- front axle screw: 61 Nm
- clamp bolt: 20 Nm
- front brake calliper: 40 Nm
- rear wheel: 146 Nm
greets
Jürgen
Corky.....torques have been available in the Blog section for several years now.
Blogs
For those unaware of some of this large websites pluses there is on the main page menu list a section titled "Blogs".
Here amongst other things is a technical section where you will find that people like OND (he has done quite a few) have taken time to do step by step procedures for a number of modifications and maintenance issues including photographs.
If you have not seen it I suggest you browse through it.
DaveM:cool:
