I recently put a new on/off switch on my bike because the old one was damaged in a crash, flushed coolant, installed new tail light, and changed oil in my 2007 S3. I test rode it, ran fine. after putting my rear fairing back on and cleaning the garage I decided to go for a ride. NOTHING. Bike would not turn over at all. My check engine light came on for about ten seconds while I had it running, but went right off. I tested a few things.
Battery is pumping around 12 v
But there is no power going to cylinoid. Does any body have any advice???? It ran fine when I tested it out. I am so lost/bummed out right now.
Thank you
Thank you
I have no idea what a cylinoid is but whatever it is, it sounds like it should have power going to it. Online diagnosis is hard, so check the fuses, then get a simple 12v tester (the type with a crocodile clip a wire and a screwdriver that lights up) and start at the cylinoid and work your way back to the battery.
We aren`t allowed to pass PDF`s of wiring diagrams from workshop manuals around as it breaches copywright but if you feel a wiring diagram would help and drop enough hints about needing one, there is a distinct possibility that one might turn up in your PM box.
I used a tester. Couldn't find anything. So my brother in law and I decided to go peice by peice. It ended up being clutch safety switch. Now I am back riding. Except... I need my fork seals redone.
