1 - 2 of 2 Posts
Came across some parts from a 07 1050 speed 3 and was wondering if these parts can be swapped into / onto my '02 955 speed 3.
- will the front and rear wheels work on my 02? Both Single Swingarm
- will the 1050 motor swap into my frame? what mods would have to be made? I understand the 1050 is just a stroked 955. Maybe intake needs to be modded along with exhaust? thats all I can thing of.
Thanks in advanced.
(Please don't bump after only 4 hrs - have some patience for a response)
Front wheel won't work - no speedo drive and 25mm axle on later wheel vs 20mm on earlier; rotors are not interchangable and will be too wide on the late wheel for the early forks/calipers.
1050 motor will physically fit - ideally you'll need the wiring harness & ECM to do it right; you may be able to make the Sagem ECM work if you can custom tune (with Tuneboy or PC3). Things like speedo drive (off final drive, not front wheel) will be problematic though - possibly fix that with a speedhealer and custom wiring - or ignore it & use the front wheel sender. Other sensors can possibly be worked out with some forethought.
I'm not sure about airbox - may need the later one from 1050.
1 - 2 of 2 Posts
