Just brought home a 2006 Speed Triple without a user manual and can't figure out how to reset the trip meter or set the clock and all that. All the dealers are closed tomorrow (Sunday IL law...spit). Can anyone give some direction to a new S3 rider?
to reset the clock.......select clock display and press BOTH "scroll" and "set" buttons together.After a short time,the clocks hour display will start to flash.
To reset the hour display ensure that the hour display is still flashing and press the "scroll" button to change the setting.Each press will change the setting by 1 digit.
When the correct hour display is shown, press the "set" button. The minutes display will start to flash, Adjust using same method.
Once the hours and mins are correctly set, press the "set"button to confirm the setting.The display will cease to flash.
To reset the trip computer only........select one of the trip displays, press the "scroll" and "set" buttons at the same time. After 2 seconds the trip will reset.
