1 - 3 of 3 Posts
Hi guys having big problems with my front calipers. Had a leaking caliper one which I had rebuilt a while ago with new st /st pistons and seals . So decided to get both calipers professionally reconditioned. They came back from shop I fitted them & the same one was leaking, turns out they had changed seal suppliers sent them back so that they could put things right. Got them back fitted them & same one leaked very slightly. The other one was sticking on all new st/st pins boots and lubricant. Only thing I can put it down to is the Explorer master cylinder that I had fitted to improve the feel of the front brakes. Any Answers gratefully received .
I think you will find that towards the end of the post I mention that the right hand caliper is sticking on , and was asking if it could be the master cylinder causing that problem .
1 - 3 of 3 Posts
