Has anyone tried this install? Seems they will work, as the bolt spacing is the same. Major difference is that the 03s are curved outward as opposed to straight down for the earlier ones. Just wondering if it will look satisfactory or not.
98 Peg:_________03 Peg:
Really?? Any specific year or displacement?
Pretty much all 01 -06 at least, all engine size GSXRs. The styles also change a little between the years but they all have the same mount spacing (70mm from memory, but you should validate that!)
You may also want to validate the exhaust hanger bracket - I didn't use it on mine with after-market exhaust (which uses the same subframe footpeg mounts)
I may have a picture somewhere with the GSXRs on - I'll try to dig one out.
