1 - 3 of 3 Posts
Hello Ya all, I got a project bike 2002 TT600 kind of came in pieces and was laid down. It came tank off, and a few other pieces had to assemble cooling system and fairings.
Following items have been cleaned or checked as working.
1. Fuel Pump, Fuel Injectors, fuel tank, and fuel lines
2. spark plugs, coils
3. Air cleaner filter and box cleaned.
4. Radiator and cooling fan
Today started the bike, it fired up and rev'd up to 14000 plus RPM, so i turned it off. Started 2 more times each time did the same. I twisted throttle to see if it would change RPM. it did not. When throttle is twisted the throttle plates respond accordingly. So its not mechanical. I believe its electronic issue. I ordered a new EFI relay. My thinking is ECU is working because it started. Any Ideas on what would make it rev up to max... w throttle not open....
Open or undone issue; My thinking is one of these must talk to the ECU...my guess...any thoughts..
a 2 wire male fitting is unplugged and i cannot find where to plug it in?
a 4 wire female fitting is unplugged and taped up under fuel tank and not sure where or what it plugs into
Thanks would appreciate any guidance or thoughts on the issue. Paul
Administrator
Welcome to the forum!
The Triumph SuperSports forum is where you can connect with other TT600 riders. The folks there will best be able to assist you. Introduce yourself there, post photos of your TT600, and join the banter.
http://www.triumphrat.net/triumph-supersports/
Connect with local riders in the RAT forums. If you do not see a thread for your area, please start one.
http://www.triumphrat.net/rat-west/
You may also find local riders and local events in the Rides and Events forum.
http://www.triumphrat.net/rides-and-events/
Please share your rides with us by posting photos of your rides in the Ride and Trip Reports forum.
http://www.triumphrat.net/ride-trip-reports/
Enjoy some off-topic and often humorous conversations in the Biker Hang Out forum.
http://www.triumphrat.net/biker-hang-out/
There is much to our forum, so please make yourself at home, browse the forums, and join the conversation where ever it may interest you. We are happy to have you here.
Cheers!
1 - 3 of 3 Posts
