Help! Tore into the top end of my engine today due to an unfortunate event. Low speed gravel slide frame slider bent (didn’t save the Fairings) cracking the cylinder/valve case near the valve cover. Picked up a replacement case and I want to get it back together while I have the time this weekend and I don’t know how hard it will be to find a repair manual on a Sunday. If anyone could help me out on torque values for the case, the four cam bolts, the cam plate, and the valve cover. All help would be very much appreciated, thanks!
thanks Drakewn, that will get me in the direction I was wanting to go until I can pick me up one of those manuals. Thanks again.
4given, The way I read the manual you'll need to reseal the cylinder liners. You might want to hold off 'till you get a manual.
Brad
Brad, I know thats what I need to do just was trying to get it done while I had the time this weekend. Probably going to order the manual off of amazon or something and wait till it gets here before I finish the project. Thanks for the input
