I've been methodically working on my project Sprint after purchasing it as potentially having a rod problem. I have not found anything of significance to show why it had a loss of power as described by the seller. I did not confirm this loss of power before pulling the head and having a good look around the top end for fear of causing more damage. I considered it had a blown head gasket as there was evidence of overheating but apparently that is not the case according to the local Triumph service manager. Before putting it back together I decided to pull the sump and see what that area looked like and all seems well, no metal bits and no foamy/oily substance. I then had a look at the crank from the bottom and see that it has a blue tint to the lobes. Would this indicate overheating and if so what might this mean for the future of the motor? The bike had apparently taken a spill and I read somewhere that if it ran while on its side the lubrication of the crank and main bearings could be compromised? I would appreciate some thoughts from the forum. Thanks-Gary
