T140D transmission shifting - Triumph Forum: Triumph Rat Motorcycle Forums
The Welcome Center New to the Site? Please take a moment to introduce yourself. New members and members who have yet not posted MUST post their first post here to activate their profiles.
post #1 of 4 (permalink) Old 05-09-2015, 06:20 PM Thread Starter
Main Motorcycle: Electra Glide
I have a T140D that I just finished reassembling with a fully rebuilt engine. Work on the engine was done by a local motorcycle that does a lot of vintage Triumph work. Just got it running and it is not shifting gears right. I cannot get it to shift into a neutral position, I can find a neutral spot in the area where the neutral light comes on but there is no sign of a detent dropping in and it's a very touchy position with wanting to drop into gear and not stay in neutral. Can the trans cam be put in backwards? when I shifted it into what should have been 1st gear and rode it it seemed to be in 3rd gear, certainly wasn't engaging 1st gear. I'm believing the cam plate is flipped over. Ideas? Comments?
studegary is offline
post #2 of 4 (permalink) Old 05-10-2015, 08:08 AM
Main Motorcycle: 09 Kawasaki KLR
Padre's Avatar
Other Motorcycle: 71 CL 350
Extra Motorcycle: Tardis
...yes, say hello. This is the welcome area.
Padre is offline
post #3 of 4 (permalink) Old 05-10-2015, 08:27 AM Thread Starter
Ooops, thought this was an area for technical questions
I'm Gary, I live in Marysville, WA. I bought my 1979 Thiumph Bonneville Special T140D about 8 years ago thinking I would make a cafe racer out of it. It had been in a storage unit for some time. Once I knew what I had I decided to bring it back to stock and not cafe it. With the help of e-bay, swap meets, etc I found all the parts I needed. It's more a preservation than a restoration. I used it off and on for several years but in 2010 it was starting to blow too much oil so it was parked. Last Sept I pulled the engine out and had a local shop totally rebuild it. Now transmission is not right.
post #4 of 4 (permalink) Old 05-10-2015, 04:25 PM
Main Motorcycle: 2010 Speed Triple.
Administrator
Sean Patrick's Avatar
Other Motorcycle: 2015 Rocket X.
Extra Motorcycle: 1969 T120R Project.
Welcome to the forum!
The Classic, Vintage, and Veteran forum is where you will find the folks with the knowledge and experience to assist you. Introduce yourself in there and repost your question. They will be happy to help you!
https://www.triumphrat.net/classic-vintage-and-veteran/
Best of luck with your project!
Cheers!
Sean Patrick
2010 Speed Triple
2015 Rocket X
1969 T120R Project
Chairman, TOMCC USA
www.tomcc.org
[email protected]
Sean Patrick is offline
T140D mainstand wol Classic, Vintage & Veteran 10 05-27-2015 04:54 AM
Reverse shifting order? 72 T120 leylandauto Classic, Vintage & Veteran 14 04-27-2015 11:41 AM
79 t140d clutch triumph79 Classic, Vintage & Veteran 16 04-24-2015 07:50 AM
T140D pillion footrest wol Classic, Vintage & Veteran 2 04-16-2015 12:04 PM
Transmission gear ratios Geezer99 Air Cooled Cruisers - America, Speedmaster 19 02-24-2015 05:15 AM
