Daytona 955i help - Triumph Forum: Triumph Rat Motorcycle Forums
The Welcome Center New to the Site? Please take a moment to introduce yourself. New members and members who have yet not posted MUST post their first post here to activate their profiles.
post #1 of 3 (permalink) Old 02-19-2015, 11:18 AM Thread Starter
Main Motorcycle: Daytona 955i CE
Coconut's Avatar
Daytona 955i help
Hi all, I have a Daytona 955i centennial edition (2002) and the crank has sheared off at the starter clutch end flush with the casing. I can't find a replacement crank (so far anyway) and was wondering if it might just be easier to get a donor engine. My bike has forged crank, con rods, pistons and liners to create and cope with 147hp compared to earlier 955i engines ranging from 108 to 128hp so I need a 2002 or newer engine. Could I fit a Daytona 06 engine into the frame? Would it be compatible with everything else? I dont fancy putting a Sprint or Speed Triple engine in because of the power loss. If I have to swap out the crank could i use any crank from a 955i 2002 or later as I think the power increase was due to the piston size and compression ratio? Any help/advice/tips etc are greatly appreciated.
Coconut is offline
post #2 of 3 (permalink) Old 02-19-2015, 12:38 PM
Main Motorcycle: 2010 Speed Triple.
Administrator
Sean Patrick's Avatar
Other Motorcycle: 2015 Rocket X.
Extra Motorcycle: 1969 T120R Project.
Welcome to the forum!
Repost your question in the Daytona Deliberations section. You will get the best answers to your question there.
https://www.triumphrat.net/daytona-deliberations/
Best of luck!
Cheers!
Sean Patrick
2010 Speed Triple
2015 Rocket X
1969 T120R Project
Chairman, TOMCC USA
www.tomcc.org
[email protected]
Sean Patrick is offline
post #3 of 3 (permalink) Old 02-19-2015, 04:14 PM
Main Motorcycle: '98 T595 Daytona
Other Motorcycle: 2014 Ninja 1000ABS
Welcome. The increase in power did not come from an increase in piston bore. All 955 Daytonas have the same bore and stroke. The 1050 engine also has the same bore, longer stroke.
Felony is online now
97 daytona t959 problems newtrumpet Daytona Deliberations 3 02-13-2015 04:48 AM
2004 Daytona 600 R/R upgrade DaytonaWMR Triumph SuperSports 3 02-12-2015 08:57 PM
Valve adjustment for 955i NDspd Speed Triple Forum 15 02-05-2015 10:00 PM
Daytona for Bonneville anyone? mjdt Air Cooled Twins Talk 2 02-05-2015 01:40 PM
Daytona valve clearance inspection caps Old Cafe Racer Classic, Vintage & Veteran 2 02-05-2015 01:12 AM
