cant balance no 1 cylinder - Triumph Forum: Triumph Rat Motorcycle Forums
The Welcome Center New to the Site? Please take a moment to introduce yourself. New members and members who have yet not posted MUST post their first post here to activate their profiles.
post #1 of 1 (permalink) Old 07-08-2014, 04:34 AM Thread Starter
Newbie
Main Motorcycle: TIGER 955I
Unhappy cant balance no 1 cylinder
Hi all, i have a 2002 Tiger 955i from new, done 42,00 miles, trouble free. I have had popping in the exhaust on deceleration, the exhaust gaskets were blowing so i thought that was the problem. replaced the gaskets and noticed no 1 exhaust was white inside , 2 & 3 weren't. then tried balancing the throttle bodies but no 1 cylinder wont get any where near the other two. tried swapping the injectors around but always no1 cylinder is half the vacuum of the other two at idle. Can you adjust the fuel to each cylinder or is that a Triumph workshop job. I also noticed that the 12 wire plug for the injector electric feed was green inside so cut n hard wired them. I have a Data tool system for getting rid of fault codes after service and balancing. I had left the lap top connected and may have hit a wrong button some where. Can anyone help?
BLUEPIG600 is offline
TB Balance pix (1) CLB ECM and FI Tuning - Help, Tips & Tricks 56 02-16-2010 12:52 PM
Gap between cylinder head and cylinder barrel. cbm206 Classic, Vintage & Veteran 7 09-07-2009 02:02 PM
Cylinder Block removal,Cylinder TDC ? argie Classic, Vintage & Veteran 2 05-04-2008 05:26 PM
Rim Balance NewOldSkool Air Cooled Twins Technical Talk 2 07-29-2007 08:28 PM
Balance Shafts andyThrux Air Cooled Twins Technical Talk 2 07-07-2007 08:22 PM
