Re installing camshafts - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 1 (permalink) Old 07-14-2019, 04:38 AM Thread Starter
Main Motorcycle: 05 rckt3
Jdrckt's Avatar
Other Motorcycle: 69 BSA 650 Lightning
Hi all, as I was replacing the torsion dampener shaft bearings I decided to check the valve clearances while the motor was out, after taking the valve clearances I removed the camshafts to measure the shims that needed to be changed, to reinstall the camshafts Iíve lined everything up #1 piston to TDC aligned with crank marks and set the camshafts back in,,, how do I know for sure that when I set the TDC the piston is on the compression stroke? Is there a way to tell without having the camshafts in place?
Jdrckt is offline
