Judder at very low rpm - Triumph Forum: Triumph Rat Motorcycle Forums
Street Triple Forum Owners and Enthusiasts of the Triumph Street Triple.
 3Likes
post #1 of 13 (permalink) Old 08-13-2019, 07:02 PM Thread Starter
Hi
recently the bike judder excessively during very low rpm, ie: below 2000 rpm.
very noticeable during heavy traffic.
just noticed how bad the judder when I put it on the race stand, put it on 1st gear and let the wheel run, it judder like crazy, but soon you open the throttle the judder gone.
I have replace the clutch pack, friction and the steel plate, but still exists.
I have done the reset adaptation as well.
Anyone know what caused this?
Many thanks
tempolong is online now
post #2 of 13 (permalink) Old 08-14-2019, 12:31 AM
Main Motorcycle: Street Triple R
Super Bananarator
MacBandit's Avatar
Other Motorcycle: 97 Honda CR250R
Extra Motorcycle: 96 BMW K1100RS
MacBandit is offline
post #3 of 13 (permalink) Old 08-14-2019, 01:57 AM Thread Starter
definitely not a chain, I suspect dirty injector,
post #4 of 13 (permalink) Old 08-14-2019, 02:36 AM
Main Motorcycle: 2004 Daytona 955i
Other Motorcycle: 2006 1050 Speed Triple
Extra Motorcycle: Vespa PX200
MacBandit offers a sensible stab at what it might be and, having already made your mind up, you dismiss it without even a thank you. C'mon, you're better than that.
Terry Colley is online now
post #5 of 13 (permalink) Old 08-14-2019, 04:17 AM Thread Starter
Thank you @Terry Colley
Thank you @MacBandit
post #6 of 13 (permalink) Old 08-14-2019, 10:57 AM
What exactly do you mean by “judder?” Mine is a bit moody at low 1st gear revs.
stowanewb is online now
post #7 of 13 (permalink) Old 08-14-2019, 04:48 PM Thread Starter
I might not use the right word, but it's like shaking
post #8 of 13 (permalink) Old 08-14-2019, 07:39 PM
Main Motorcycle: 2010 Triumph STR
Other Motorcycle: N/A
Extra Motorcycle: Cannondale Freeride MTB
There is such a thing as running an engine at too low an rpm. The Street Triple engine is happiest above 4000 rpm, and accelerating below 3000 rpm will definitely cause a transitory shudder or vibration which is normal. This is a high revving engine and does not like putting around town.
tempolong likes this.
Wayne's Striple is offline
post #9 of 13 (permalink) Old 08-14-2019, 09:12 PM
If it would pull smoothly under 2000rpm previously then it has to be something has definitely changed.
Try running the chain just a little looser. And check the countershaft sprocket nut is still tight.
Has it been in the dealers recently? Could they have loaded a different map without telling you?
post #10 of 13 (permalink) Old 08-15-2019, 09:27 AM
BKK Jack's Avatar
If it only happens while riding when trying to accelerate from very low revs - 2000 is very low revs for this engine - I would say you are lugging the engine and that you absolutely need to change your habits to stop doing this. However, you say this:
...when I put it on the race stand, put it on 1st gear and let the wheel run, it judder like crazy, but soon you open the throttle the judder gone...
Which leads me to believe you are not lugging the engine. This is good, because besides running it without oil, lugging an engine is one of the worst things you can do.
Lugging an engine is like hammering the engine parts with every explosion in a cylinder. It racks on the rod bearing/journals, makes the pistons slap the side of the cylinders hard, and if is done enough, could probably break piston rings. It also creates a hammer effect all the way through the drivetrain. There are springs in the friction disk (of the clutch) which takes up some of this hammering, but they will only take so much before they wear out as well. This causes premature wear all the way around. It's not like it will wear out tomorrow, but it will cause wear over time. If you want your car to last a while, you don't want to be doing this.
If your "judder" only happens at very low speeds in gear with the rear wheel spinning - like when you had it on the stand - then MacBandit is probably correct (good odds of that since he is an actual bike mechanic), and the judder is due to your chain, and or sprockets. If it happens at similar revs in neutral, without the chain and wheel spinning, then it's probably engine related.
Just because I'm paranoid, it doesn't mean the whole world isn't out to get me.
Words mean things.
My life is not without meaning. I can be held up as a bad example.
BKK Jack is online now
