Oil Leak 2016 Street triple - Triumph Forum: Triumph Rat Motorcycle Forums
Street Triple Forum Owners and Enthusiasts of the Triumph Street Triple.
 2Likes
post #1 of 11 (permalink) Old 07-14-2019, 11:59 PM Thread Starter
Castedu1's Avatar
For a while I noticed a few drops of oil on my slip-on exhaust. Recently I discovered where it comes. The leak is super tiny and barely noticeable.
Se images below. Any suggestions?
If I take it of, change washer for a new one and put it on, will that do?
ID:	648976   Click image for larger version
ID:	648978   Click image for larger version
Castedu1 is offline
post #2 of 11 (permalink) Old 07-15-2019, 06:29 PM
Main Motorcycle: 2012 Street Triple R
dementedbrave's Avatar
I wouldn't bother changing washers. Take the bolt out and clean off all the oil. Use a bit of liquid gasket like permatex black or grey to seal it. That is a crank case bolt, I believe the torque spec is 32 NM. I have seen that one leak before.
dementedbrave is offline
post #3 of 11 (permalink) Old 07-15-2019, 09:49 PM Thread Starter
Castedu1's Avatar
Thanks. Do I need to empty all the oil? When I remove it, will a lot of oil come out?
Sent from my iPhone using Tapatalk
Castedu1 is offline
post #4 of 11 (permalink) Old 07-15-2019, 11:21 PM
No, the oil is down lower. Do this with the engine cold.
Castedu1 likes this.
post #5 of 11 (permalink) Old 07-15-2019, 11:51 PM Thread Starter
Castedu1's Avatar
Thanks! I just torqued it to 32Nm. I will check tomorrow to see if there is any oil around. The two other crankcase bolts close by that did not leaked where also slightly under-torqued, so I put them at 32 Nm as well.
If this doesn’t work, I will work on the weekend removing the bolt and putting sealant.
Castedu1 is offline
post #6 of 11 (permalink) Old 07-16-2019, 07:28 PM
Main Motorcycle: 2014 Street Triple R
conrazy's Avatar
I'd torque the oil pan and all engine cover bolts to spec as well (in the correct order). They loosen up with time, though mine seem to have stayed tight since I did the last re-torque.
conrazy is offline
post #7 of 11 (permalink) Old 07-17-2019, 11:41 PM Thread Starter
Castedu1's Avatar
Leak is still there. I will remove bolt, clean and add some sealant during and torque again to 32Nm. I will do this on the weekend.
Any other suggestions are appreciated!
Castedu1 is offline
post #8 of 11 (permalink) Old 07-18-2019, 09:25 AM
Main Motorcycle: '15 Street Triple R
Extra Motorcycle: '70 Husq 360 cross
Replace the sealing washer also. A good NAPA store might be able to fix you up.
Bruce C is offline
post #9 of 11 (permalink) Old 07-19-2019, 01:20 AM
It is not a sealing washer really, and should not be leaking. Sealing washers are made from soft aluminum or copper, this one is steel. You would have to split the cases to really have a good look at where the oil is coming from. The quick fix is to use some liquid gasket around the bolt to seal it.
post #10 of 11 (permalink) Old 07-19-2019, 10:24 AM
Good to know.
Bruce C is offline
