Street triple 675 issues - Triumph Forum: Triumph Rat Motorcycle Forums
Street Triple Forum Owners and Enthusiasts of the Triumph Street Triple.
post #1 of 23 (permalink) Old 07-02-2019, 04:06 PM Thread Starter
New member-sussex and a friend that's has huge issues-triumph dealer no help.
Basically-cold start no probs
Warm-bad slow cranking no start.
With a jump from a car no issues.
Battery has been replaced 3 times.
Triump originally said its starter-no it's not.
I got called on as the guy fed up with triump aftercare.
So I read up about possibly coolant issues.
Dumped the coolant-dirty brown colour.
From cold starts fine-warm it up and if you turn it off then try to restart it turns over once and gives the impression of a flat battery or a partially seized engine.
Jump from a car and it fires straight up.
Used a test meter and the battery ain't charging.
So you can all guess which bike it is.
It's a speed triple 675 on a 15 plate.
Here's what I have found.
R/R reading as follows-tested at idle
Pin1-2----26.8volts ac
Pin 2-3-----24.6 volts ac
Pin 1-3----21.4 volts ac.
But readings are not steady they fluctuate around these voltages.
Same test but at 5000rpm
Pin 1-2----90 volts ac
Pin 2-3----100 volts ac
Pin 1-3----110volts ac
Should it NOT go above 70 volts ac.
Readings from stator plug only.
Second test.
Test pins 1 to 3 with + and - on the r/r only and I get readings on the positive but got no readings on the negative.
So my questions are.
Is the stator and the r/r fried or is it just the stator.
When the stator plug is unplugged for testing and you run the engine it will only run for a short while then dies.
Any thoughts or help would be appreciated as I cant get any accurate info from triumph on the limits for readings for both stator and r/r.
Regards
Kev
Speedtriple675 is offline
post #2 of 23 (permalink) Old 07-02-2019, 10:18 PM
Main Motorcycle: 2012 Street Triple R
dementedbrave's Avatar
To test a stator you want to check resistance between the 3 coils, should all be around 0.2-0.5 ohms. You also want to test each coil to make sure it is not grounded to the frame. Do these tests with the bike off. Also if your coolant is a dirty brown color, it is likely getting mixed with the oil. That could mean your waterpump seal is bad, or possibly a leaking head gasket which may cause your engine to lock up because of coolant in the combustion chamber.
dementedbrave is offline
post #3 of 23 (permalink) Old 07-03-2019, 01:11 AM Thread Starter
The coil
Did that and had no reading to bike frame
It was over limit on the meter indicated by OL on the meter, the meter is a digital auto range with selectable volts,ohms,diode and continuity ac/DC selectable.
The coolant didn't contain oil as no oil was present it was just a dirty colour, bit like weak tea without milk.
The one reading I did get that was accurate was on diode test all three phases read 0.42 to the + of the r/r but OL on the negative. If I swap the red and black cable round for the meter and place the red on the neg of r/r then I got 0.92 on diode test for each phase but nothing on the positive .
Just a little confused as to what's actually playing up.
post #4 of 23 (permalink) Old 07-03-2019, 11:04 PM
Second test.
Regards
Kev
This is exactly what happened with me, after I replaced the stator with cheap chinese one. If you leave it until the engine is cold, it will start again no problem.
ST 765 RS (Gone)
STR 09 (Gone)
ST 08
S1000R 17 (Gone)
W800SE 12
tempolong is offline
post #5 of 23 (permalink) Old 07-04-2019, 02:09 AM Thread Starter
So tempolong have you cured it.
What did you do.
R u still riding the beast or have you sold it on.
post #6 of 23 (permalink) Old 07-04-2019, 06:40 AM
Not yet, this weekend I'll try to swap the stator, and let you know, really weird issue,
When warm and difficult to start, you can try to open the throttle up sometimes it works.
post #7 of 23 (permalink) Old 07-05-2019, 03:59 PM
Main Motorcycle: 2008 Street Triple
Conspiers's Avatar
Your problem sounds similar to my past 3 months: After going through 5 batteries, a Voltage Regulator, and Stator (I gave up self repairing here), it ended up being the Starter. It would cold start fine, but when hot required a ton more current. It took the shop several rounds to conclude this. My bike is now running (and starting) great.
Conspiers is online now
post #8 of 23 (permalink) Old 07-06-2019, 12:07 AM
Originally Posted by Conspiers View Post
Your problem sounds similar to my past 3 months: After going through 5 batteries, a Voltage Regulator, and Stator (I gave up self repairing here), it ended up being the Stater. It would cold start fine, but when hot required a ton more current. It took the shop several rounds to conclude this. My bike is now running (and starting) great.
Hey @Conspiers , did you mean Starter motor?
ST 765 RS (Gone)
STR 09 (Gone)
ST 08
S1000R 17 (Gone)
W800SE 12
post #9 of 23 (permalink) Old 07-06-2019, 02:00 AM Thread Starter
I have just found out it's a street triple r on a 13 plate.
So could make a difference to solving the issues this thing has.
post #10 of 23 (permalink) Old 07-07-2019, 12:09 AM
Conspiers's Avatar
Yes, typo. The starter motor was bad when hot. It took a while to conclude.
