675 STR sweet setup - Triumph Forum: Triumph Rat Motorcycle Forums
Street Triple Forum Owners and Enthusiasts of the Triumph Street Triple.
 1Likes
  • 1 Post By rc1029
post #1 of 7 (permalink) Old 03-03-2018, 01:54 AM Thread Starter
Main Motorcycle: 2015 Street Triple R
Other Motorcycle: Sold 'em... love the STR
675 STR sweet setup
I have finally found the mountain corner carving overall setup that feels like a real sweet spot for my 2105 Street Triple R...
My goal was to end up with the best combination of cornering performance + ride comfort and all at a "moderate" price..... with the bike to be used primarily on curvy mountain roads in my area.
Shared as ideas for you all with a late model Street Triple 675 and similar riding goals...
Making the bike as light as possible without spending much: Removed around 30+ pounds from the bike (tail assembly, passenger footrest assembly, lead/acid battery, mirrors, stock exhaust, fly screen, belly pan).
Suspension:
Front - Race Tech springs and Motul 2.5W oil (centistoke 15) with 130mm air gap. Rebound 12 out and Compression 15 out. Fork tubes moved 5mm thru the triple trees. Total sag at 40mm.
Rear - UKRace shock linkage (straight rate linkage.. no passengers now allowed). Ohlins spring on stock shock. Rebound 10 out and Compression 17 out. Total sag at 30mm.
Tires: Pirelli Supercorsas. 32psi front, 38psi rear.
Exhaust: SC-Project conical with Triumph aftermarket exhaust map. Improved throttle response and control...
After a fairly lengthy journey of experimenting, this setup feels like my best compromise of feel, control, engine performance, ride plushness and cornering performance....
Anyone else willing to share their setup, in detail?
I am always interested to hear different setup ideas that work also...
rc1029 is offline
post #2 of 7 (permalink) Old 03-03-2018, 10:00 AM
Main Motorcycle: 2018 Street Triple 765 R
Other Motorcycle: 2009 Buell XB12R
Extra Motorcycle: 2000 Buell Blast
Pictures?
vicenzajay is offline
post #3 of 7 (permalink) Old 03-03-2018, 05:40 PM
Main Motorcycle: 2014 Street Triple R
analog's Avatar
Weight savings by removing the flyscreen and bellypan is probably negligible, especially because the belly pan's weight is the lowest part on the bike.
Also, thanks for posting your suspension setup but its useless unless we know the rider weight.
2014 Street Triple R ABS
Past: 2011 Street Triple R, 2016 Yamaha FZ-09, 2016 Yamaha FZ-07, 2014 Kawasaki Ninja 300
analog is offline
post #4 of 7 (permalink) Old 03-04-2018, 04:17 AM Thread Starter
Oooops. You are right: Rider weight - 180lbs.
Note: Racetech springs front fork are .85kg
Note: correct that bellypan removal has negligible effect.... but I am saying losing 2 lbs. is still 2 lbs.... it adds up...=)
vicenzajay likes this.
rc1029 is offline
post #5 of 7 (permalink) Old 03-04-2018, 04:23 AM Thread Starter
And those original, bug-eye headlights.... 5 lbs. just waiting to be removed.... but what to replace them with that saves alot of weight?
I bought a single headlight - aftermarket LED.... would look great..... but due to the heat sink at the back of the light it weighs nearly the same as the two original bug eyes together (I am not in love with the bug eyes).... anyone have lightweight replacement ideas for the "headlight"?
rc1029 is offline
post #6 of 7 (permalink) Old 03-07-2018, 05:29 PM
Main Motorcycle: '10 ST3
Other Motorcycle: '07 SV650S
How do you think you would feel on long distance commuting with that setup? (negating the tires in regards to lifespan)
LRCst3 is offline
post #7 of 7 (permalink) Old 03-08-2018, 12:30 AM Thread Starter
my setup is purely for ripping around my local mountain roads....=)
so in that sense it is by nature a very focused, limiting style of setup... a "sweet setup" only for corner carving...=)
rc1029 is offline
Daytona 675 front wheel in 05 955i PaulM Daytona Deliberations 2 07-03-2017 02:30 AM
15/49 Sprocket setup for '15 STR alecellis Street Triple Forum 14 11-28-2016 06:13 AM
Goodbye sweet 675, Hello 865! StanS3 Air Cooled Twins Talk 26 10-20-2016 01:42 PM
Daytona 675 : unstable front end? Ricci Daytona675 Forum 8 03-15-2016 03:33 AM
