'Normal' mirrors on RS - Triumph Forum: Triumph Rat Motorcycle Forums
Street Triple 765 Talk about the Street Triple 765 model
post #1 of 10 (permalink) Old 06-01-2019, 06:54 PM Thread Starter
Main Motorcycle: Street Triple RS
I'm getting ready to pull the trigger on an RS. I'm not a huge fan of bar end mirrors as I have a city commute through traffic some days and try to keep things as slim as possible.
I can't find any info online but does any owner know if the RS has standard mounting holes for mirrors? Anyone tried it?
All advice and experience welcome!
mattco is offline
post #2 of 10 (permalink) Old 06-01-2019, 07:51 PM
Main Motorcycle: Triumph Tiger 800 XCA
Other Motorcycle: Triumph Street Triple RS
It does not have mount points for standard mirrors, but you should be able to find parts to mount them by replacing these clamps.
NEPAChuy is offline
post #3 of 10 (permalink) Old 06-02-2019, 12:04 AM
Main Motorcycle: 2017/18 Street Triple RS
tushalb's Avatar
https://www.amazon.com/Doubletake-Mi.../dp/B07BHVYK3J
Take a look at these!
Sent from my SM-G950F using Tapatalk
Previous rides:
2013 Kawasaki Ninja ZX-6R (636)
2005 Honda Hornet CB900/919
2001 Honda Hornet CB250
2000 Bajaj Pulsar P180
tushalb is offline
post #4 of 10 (permalink) Old 06-02-2019, 03:36 AM Thread Starter
That's really helpful. thanks.
I can't see how the mirrors are mounted on the current model R or S but looks like I can bodge this with the brake side clamp from a 17-19 and the clutch side from a pre-17.
If anyone is interested, looks like parts are here:
Left side mirror mount clamp PFKL1203633 (part #2)
https://www.worldoftriumph.com/parts...100061227-1-2/
Right side mirror mount clamp - PFKL3024152 (part #4)
https://www.worldoftriumph.com/parts...100082708-0-2/
(Let me know if links violate rules...)
Or, I'll just keep the damn bar end mirrors and get used to it. I'm really excited about this bike.
mattco is offline
post #5 of 10 (permalink) Old 06-03-2019, 05:39 AM
Main Motorcycle: Triumph Explorer
Other Motorcycle: 765R
Extra Motorcycle: 1950 Guzzi Falcone
Buying the clamps would let you fit a wide choice of aftermarket mirrors but personally I wouldn't even contemplate the stock Triumph ones from R or S models: They're rubbish unless you want a good view of your elbows and the way the lens "adjusts" in the plastic mirror body is primitive & insufficient.
Will Morgan is offline
post #6 of 10 (permalink) Old 06-03-2019, 12:30 PM
Main Motorcycle: 2018 Street Triple R-LRH
graniterid3r's Avatar
Yes, you should be able to just replace the clamp. Folks like me with an R have done the opposite: replace the mirror mount clamp with a bare clamp. The bare clamps are the same as the Daytonas from like 12+ I think. Clutch side should be the same, but I'm unsure about brake side since the RS has a different MC.
That said, can't you turn the stock bar end mirrors towards the inside? My CRG arrows allow that, though I ride with them to the outside. As Will said, the stock R mirrors are terrible, so unless you find some aftermarket ones that are better, the small amount of width saved is likely offset by less useful mirrors.
2018 Street Triple R - LRH, Crystal White - ASV levers, passenger peg delete, tailtidy, and cowl.
graniterid3r is offline
post #7 of 10 (permalink) Old 06-03-2019, 03:04 PM Thread Starter
Iíve got a set of Rizoma mirrors on the Bonnevile that I really get on with. Iím reverting to stock and part exchanging for the Street Triple so wanted to transfer them over if possible. If not, theyíll go on eBay with the rest of the bits and pieces I added to the Bonnie.
Thanks for the heads up on the stock S / R mirrors!
Sent from my iPhone using Tapatalk
mattco is offline
post #8 of 10 (permalink) Old 06-03-2019, 03:09 PM Thread Starter
Thanks for the details! Yeah, I saw that the brake side clamp will probably be a different colour - if it even fits at all.
As I mentioned to Will, I like my current Rizoma set so would be cool to keep them if possible. On the test ride from the dealer, I thought the stock bar ends were serviceable at best but would definitely look to swap them out either way.
mattco is offline
post #9 of 10 (permalink) Old 07-07-2019, 04:05 AM Thread Starter
Reviving this thread for a bit of advice.
Got some clamps that work well (ended up picking up some from Rizoma which work great).
Of course, there's another hurdle. Pulling off the OEM bar end mirrors and finishing cap revealed a threaded post / insert sticking out the end of the bar that I'm not sure is removable. I have some bar end weights already that I wanted to use but they're the expanding rubber fitment type so need a hollow bar.
Do you know what this part is (I can't find a reference online) and if it's removable? You can see the wiring for the heated grips in the picture so that might cause problems with a push fit anyway. If not, any recommendations for bar ends? Would be great to not have the gap as well between the end of the grip and the bar end.
mattco is offline
post #10 of 10 (permalink) Old 07-07-2019, 06:21 PM
Main Motorcycle: 2018 Street Triple RS
StripleRS's Avatar
Ah yes, went though this myself. Itís a clever setup triumph has there but it does limit oneís mirror options if you want to use heated grips as well. Heated grips were important to me so I left that piece inside the bar. I had a nice set of motivation weighted bar end/mirror mounts that couldnít be used, I was bummed.
I ended up installing CRG Arrow bar-end mirrors on what left of the bar extending past the grips. You could then screw the caps back on but I ended up using sliders instead. Works for me.
StripleRS is offline
