Street Triple Shut down HELP! - Triumph Forum: Triumph Rat Motorcycle Forums
Street Triple 765 Talk about the Street Triple 765 model
 4Likes
post #1 of 15 (permalink) Old 05-16-2019, 10:18 PM Thread Starter
Main Motorcycle: Street Triple RS
Other Motorcycle: Totaled 1998 BMW
Hey hive mind!
So I was riding my Street Triple RS and out of nowhere all the electronics shut down. Now when I turn the key only the LED lights and the tail light turn on. No screen, nothing. Tried to jump it and didn't work. Could really use some suggestions. Thanks!
Millsymills is offline
post #2 of 15 (permalink) Old 05-17-2019, 12:00 AM
Main Motorcycle: Triumph Tiger 800XC
NORTY FLATZ's Avatar
Other Motorcycle: 2016 Harley FXDL,
Extra Motorcycle: 2018 Husqvarna 701E
Check your side stand switch. Be sure you're in neutral.
Did you follow
F
I
N
E
C
MSF RiderCoach. Retired!
NORTY FLATZ is online now
post #3 of 15 (permalink) Old 05-17-2019, 08:35 AM
BKK Jack's Avatar
Did it die while you were riding it, or did it refuse to restart after a stop? My 675 had a somewhat similar issue that turned out to be the main connection to the gauges. However, from what I've read here in the past, it appears you may be the victim of a failed dashboard. Hopefully, you are still under warranty.
Just because I'm paranoid, it doesn't mean the whole world isn't out to get me.
Words mean things.
My life is not without meaning. I can be held up as a bad example.
BKK Jack is online now
post #4 of 15 (permalink) Old 05-17-2019, 12:07 PM
Main Motorcycle: 2018 Street Triple 765 RS
CR_Biker's Avatar
Other Motorcycle: 1991 BMW K100 RS
I have heard of the dashboards failing, it happened to a guy on you tube I follow - with him it was a Tiger 800 but it had a very similar dash. I also hope it is still under warranty because apparently a new dash is around 900 pounds.
CR_Biker is online now
post #5 of 15 (permalink) Old 05-17-2019, 10:40 PM
Main Motorcycle: 1938 Speed Twin
These new dashes do not breed much confidence... I'm not sure why the bike needs the dash working in order to run.
drz1050 is offline
post #6 of 15 (permalink) Old 05-18-2019, 06:40 AM
BKK Jack's Avatar
Neither am I, but based on my experience, it isn't completely new. My 675 would also cut out, or not start without every pin in the connector to the dash making solid contact. I imagine it has something to do with the ECU and dashboard communicating with each other.
Words mean things.
post #7 of 15 (permalink) Old 05-18-2019, 06:37 PM
Wonder if that could be jumpered.. You remember what kind of connector it was/ how many pins?
drz1050 is offline
post #8 of 15 (permalink) Old 05-19-2019, 10:07 AM Thread Starter
I made a few calls to different dealers to figure out the potential problem. The odds are that it is the dash (one dealer was in the process of fixing the same problem), but of course there is no way of knowing till the motorcycle is checked over. The problem for me is that I am moving at the end of the month cross country (US), so I won't have to the time to get it fixed (In DC it's 3 weeks to have it looked at and 1 month to get a replacement part). So I guess I won't be doing my cross country motorcycle trip after all. On the bright side, it failed close to home instead of the middle of kansas so...
post #9 of 15 (permalink) Old 06-11-2019, 02:08 AM Thread Starter
Figured I'd give an update. Turned out to not be as catastrophic. The kind folks at San Diego Triumph (really cant speak highly of them enough) looked it over and found that it was the ignition wiring that shorted if I remember correctly. So it looks like I will be getting my bike back Waaaaaaaaaay sooner that I though. So that's fun
Also, my bike was out of warranty but Triumph still honored the repair, so that's awesome too!
Rayvin and DandyLion like this.
post #10 of 15 (permalink) Old 06-11-2019, 07:38 AM
BKK Jack's Avatar
Great News!
Words mean things.
Potential, new Street Triple 765 owner harrell53 The Welcome Center 12 02-26-2017 01:34 AM
Street Triple to Dirt Triple Conversion? Can it be done? Mooney S3 Street Triple Forum 12 02-15-2017 04:34 AM
WOODCRAFT TECHNOLOGIES - New Product Development - Street Triple - NEED FEEBACK! frank20 Street Triple Forum 31 11-24-2016 07:49 PM
Help me decide between 2016 Street Triple RX and Street Triple R triplestreet Street Triple Forum 32 06-21-2016 11:57 PM
Daytona lower fairings on a 2014 Street Triple R thousandwords Street Triple Forum 0 08-12-2014 07:17 PM
