Ignition Cylinder Steering Lock -- Push? - Triumph Forum: Triumph Rat Motorcycle Forums
Street Triple 765 Talk about the Street Triple 765 model
post #1 of 10 (permalink) Old 10-04-2018, 08:55 PM Thread Starter
Main Motorcycle: 2018 Street Triple RS
asellus's Avatar
The lock cylinder indicates it needs to be depressed in order to go from 'off' to 'lock' as is normal for most bikes I've been on.
My RS's cylinder doesn't actually need to be pushed in, making it really easy to flick over to the parking lights. I can twist from 'on' to 'lock' with little to no resistance. It CAN be pushed in the regular quarter inch or so, but that actually prevents it from turning.
Seems abnormal to me. The weather's a bit chilly here so going to the dealership is less than appealing, so I figured I'd ask here instead! Anyone else have this issue?
No img tags allowed in sig blocks. This hurts the asellus. :(
asellus is offline
post #2 of 10 (permalink) Old 10-04-2018, 10:59 PM
DandyLion's Avatar
My R is the same way. Does seem like it shouldn't be that way. I once killed my battery when I parked my bike around noon only to come back later at night to see I'd gone all the way over to the parking lights. Real careful to check it now.
DandyLion is online now
post #3 of 10 (permalink) Old 10-05-2018, 12:53 PM
Main Motorcycle: Street Triple 765R
Other Motorcycle: Suzuki DRZ400E
Done that on my Suzuki too. It's not uncommon. It teaches you to look back at your bike as you walk away.
DaytonaDave is offline
post #4 of 10 (permalink) Old 10-05-2018, 01:08 PM
Main Motorcycle: '98 T595 Daytona
Other Motorcycle: 2014 Ninja 1000ABS
I have the opposite on my Ninja1000. I insert the key and have to push in to turn to ON. Never experienced that on a bike before. Haven't tried to use the lock feature yet.
Felony is online now
post #5 of 10 (permalink) Old 10-05-2018, 01:30 PM
BKK Jack's Avatar
The sequence on my 13 befuddled me a bit. I was used to having to push and turn, but on this bike it seems the proper sequence is push, release, then turn.
I've mentioned this before but, the best way to turn your key to lock and be 100% sure you haven't accidentally left your parking lights on is to always turn it all the way to the stop (parking lights), then turn it back to lock.
Just because I'm paranoid, it doesn't mean the whole world isn't out to get me.
Words mean things.
My life is not without meaning. I can be held up as a bad example.
BKK Jack is offline
post #6 of 10 (permalink) Old 10-06-2018, 05:45 AM
Never once gone over to the parking light, alternatively I’ve had it frequently where I’ve tried to turn the key to engage the steering lock and it wouldn’t turn properly so the only way to solve it was to give the bars a slight nudge further to the left, almost like they needed an extra mm or 2 to allow the lock to engage properly.
Mr Knight is offline
post #7 of 10 (permalink) Old 10-06-2018, 12:12 PM Thread Starter
asellus's Avatar
Originally Posted by Mr Knight View Post
Never once gone over to the parking light, alternatively Iíve had it frequently where Iíve tried to turn the key to engage the steering lock and it wouldnít turn properly so the only way to solve it was to give the bars a slight nudge further to the left, almost like they needed an extra mm or 2 to allow the lock to engage properly.
Yeah that's pretty normal. My Kawasaki will only lock when full left, dead center, and full right.
asellus is offline
post #8 of 10 (permalink) Old 06-16-2019, 02:13 PM
Newbie
Rontrose's Avatar
I agree. Compared to my SV I really had to turn it as far to the left as I could on my 2018 STR. Works well and thanks to y’all I didn’t make the mistake of going all the way to the parking light which I don’t see a real need for. Maybe for night time photo shoots?
Rontrose is offline
post #9 of 10 (permalink) Old 06-16-2019, 03:43 PM
The PARK feature is an old feature that seems to not go away. Let's say you stop at night on the side of the road or break down, etc. Center lamp and tail do not draw much power for keeping yourself lit up.
post #10 of 10 (permalink) Old 06-17-2019, 08:02 AM
BKK Jack's Avatar
It was probably one of those DOT regulations that goes back to candles and oil lamps that will never change.
Words mean things.
BKK Jack is offline
steering lock issue 07 sprint Couchwarrior Sprint Forum 9 06-09-2018 04:10 AM
Final chance for steering lock key ? Back2-2 Air Cooled Twins Technical Talk 49 12-01-2016 04:14 PM
Need some help. Bonny steering lock Back2-2 Air Cooled Twins Technical Talk 7 10-16-2015 08:38 PM
Steering lock & cam timing Ronnie O Sprint Forum 25 05-27-2015 01:21 AM
Bonneville T100 spare ignition and steering lock help. TheRegulator Air Cooled Twins Talk 15 03-23-2015 09:41 AM
