Auto blipper anyone? - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
Street Triple 765 Talk about the Street Triple 765 model
 16Likes
post #21 of 36 (permalink) Old 07-31-2018, 04:35 PM
Main Motorcycle: 2018 Street Triple RS
Other Motorcycle: 2014 Ducati MTS GT
Definitely interested in people's experiences with the RB QS.
What's the total cost for getting the RB QS?
'18 Triumph Street Triple 765 RS
'14 Ducati Multistrada 1200 Granturismo
EvilSteve is offline
post #22 of 36 (permalink) Old 10-19-2018, 10:56 PM
Main Motorcycle: Street Triple RS
https://youtu.be/2PulEN8otWI
Sorry took a really long time to post this.
sindefectos is offline
post #23 of 36 (permalink) Old 10-20-2018, 01:31 AM
Main Motorcycle: 2016 Thruxton 1200
CanberraR3's Avatar
Other Motorcycle: 2018 Street Scrambler
Extra Motorcycle: 2016 Tiger 800 XCX
Originally Posted by Neshotosam View Post
Has anyone put a quickshifter on a Thruxton R?
You obviously got the typical RAT non-response here, but have you had any information on this? Would be a nice thing on the Thruxton.
CanberraR3 is offline
post #24 of 36 (permalink) Old 10-20-2018, 02:17 AM
tubi's Avatar
Nice. And nice Shoes!
Sent from my iPhone using Tapatalk
tubi is offline
post #25 of 36 (permalink) Old 10-20-2018, 09:19 AM
Main Motorcycle: 2018 Street Triple 765 R
Other Motorcycle: 2009 Buell XB12R
Extra Motorcycle: 2000 Buell Blast
So do you need the fueling module as well as the qs/auto blipper kit? I'm trying to wrap my head around the install and all the connections required).
vicenzajay is offline
post #26 of 36 (permalink) Old 10-20-2018, 11:27 PM
Yes you’ll need both, either EVO or RACING module and the Shift Assist kit. Shift Assist kit will not work on it’s own as it needs to plug into the EVO/RACING ECU.
post #27 of 36 (permalink) Old 10-20-2018, 11:34 PM
That's what it looked like.....
post #28 of 36 (permalink) Old 03-07-2019, 06:31 PM
Main Motorcycle: Street Triple 765 RS
Beefymcshazmoo's Avatar
Other Motorcycle: 76' honda 550 four
Just ordered a Rapidbike EVO and the shift assist module last night. The auto blip downshift just sounds to good to not have in my life.
Beefymcshazmoo is offline
post #29 of 36 (permalink) Old 03-13-2019, 03:40 AM
This one is an interesting option:
https://www.ukracesupport.com/collec...fdF1sQA9HGNcH4
Fitting guide.
First, remove the fuel tank.
This exposes the air box. Remove this completely.
Now you will see the throttle bodies and the throttle servo motor. Unplug the large connector connected to the servo motor. Plug our unit in to the servo motor and then plug the OEM connector back in to our unit.
You now have 4 other wires with connectors on our unit. One connects the Quickshifter sensor. One is for the COM port. One is for the *BUTTON and the last is for the *CAN connection
If you have the Lite version you only need to connect the Quickshifter sensor to the unit and you will need to have the COM port in an easily accessible location so you can connect to the unit for programming and for any future firmware updates.
If you have the Pro version you will also need to connect your button to the BUTTON plug and the CAN plug to the diagnostic port on your bike. Route the BUTTON wire to a convenient place and fix this to the location of choice. We recommend the handlebar.
Route the wires so they are not in danger of being trapped by any components when you put the bike back together.
Now connect the sensor to your shift rod. When routing this wire please make sure if you use cable ties that you do not over tighten them and damage the sensor wire.
Now re assemble the bike.
Open the PC software which is available for download on our website under downloads.
Connect the supplied USB lead to the COM plug and turn the ignition on to the bike.
IT IS VERY IMPORTANT TO CALIBRATE THE THROTTLE BEFORE YOU PROCEED. This only needs to be done once after install.
On the GENERAL tab click on “Start Throttle Calibration” A pop up window will open and say “Move throttle from min to max a few times AFTER clicking Okay”, open and close the throttle a few times all the way to the stop and back, 3 times should be enough.
Once you have done this, click on “End throttle calibration”
If you click on DASH in the top right of the program you will now see your throttle position displayed under TPS%. If you do not, repeat the Throttle Calibration Process again.
Sensor set up.
Shift direction. Firstly, we need to set the direction for up shifting.
Set this to C (compression) if when you are upshifting you are compressing (pushing) the sensor.
Set this to E if you are extending (pulling) the sensor when you are up shifting.
Sensitivity. You want this number to be as low as possible to give a nice positive shift. If you set this number too high (too sensitive) then the sensor will trigger the shifter/blip time before the gear physically begins to change. This could result in false neutrals. If this is set too low (not sensitive enough) then the gearbox will not be unloaded and therefore you will not be able to change gear.
We recommend starting at 65% and proceeding from here. The amount of mechanical force on different bikes and even different aftermarket rear sets will determine this so you may or may not need to alter this.
Lite Setup.
Shift Kill Time. Set this for the amount of time in ms you want to unload the gearbox for to allow the next gear to engage. We recommend starting with 62ms.
Blip Throttle %. Set this for the amount of throttle blip/opening you want for when you change down a gear. We recommend 40%
Blip time. Set this for the duration you want the throttle blip to last. We recommend starting at 60ms.
But it`s quite expensive Ł 500 ex VAT + shipping...
//M
Tripleboo is offline
post #30 of 36 (permalink) Old 04-02-2019, 08:21 PM
Main Motorcycle: Leather office chair
TTRIgnitionSystems's Avatar
Other Motorcycle: Red velour-ish recliner
Would you like to? I'm a new vendor-member on the site specialising in quickshifters, and this sounds like an excellent market opportunity. If you're interested in working with me as a research and test subject, I would supply all parts for free and you'd get to keep the final model.
Thoughts?
"Teaching Old Bikes New Tricks"
Shift Sensors - Quick Shift Controllers
North American Distributor for Shifting ContRoll
=> Bolt-on / Plug-in QS kits for Triumph Daytona & Street Triple
=> Bolt-on / Plug-in Reverse (GP) Shift kit for Triumph Daytona & Street Triple
Details in my vendor thread => New Dealer - TTR Ignition Systems
TTRIgnitionSystems is offline
Special Tool, Auto Advance Unit removal, T140? Rod Rocket Classic, Vintage & Veteran 9 03-17-2018 02:19 PM
New Auto Flasher Cancel System Tornado99 Water Cooled Twins Talk 3 02-05-2017 04:24 PM
Question re: Dynojet Auto Tune AT-300 joey1970 Thunderbird Cruiser Chat 4 04-09-2016 07:07 AM
Auto Advance Removal o1marc Classic, Vintage & Veteran 5 03-23-2016 09:51 PM
T20 auto advance springs take-it-slow Classic, Vintage & Veteran 26 07-16-2015 10:23 AM
