Luggage Options for Street Triple 765 - Triumph Forum: Triumph Rat Motorcycle Forums
Street Triple 765 Talk about the Street Triple 765 model
 30Likes
post #1 of 141 (permalink) Old 02-25-2018, 01:58 AM Thread Starter
Newbie
I want to add some luggage capacity to my RS, and I'd like hardcases for their lockability and waterproofing–I've used soft bags in the past. Unfortunately, nobody quite seems to make a touring hardcase luggage setup for the 765. In scouring for one, I've found quite a few luggage options, which I figured I'd post here for anyone else interested. If you know of any more (existing or rumored), please post!
I believe all of these options will require either drilling rear plastics to access mounting holes, or purchasing the Triumph Passenger Grab Rails (A9758174), which should include a pre-drilled undertray. (install instructions)
Luggage Options
Givi: 6412FZ top rack and ST601 Multilock sidebags
Givi has a hard top case and "thermoformed" side bag setup. Probably the closest thing to a full hardcase setup right now?
https://www.givi.it/soft-bags/Saddle...01%20Multilock
Hepco & Becker Sportrack top rack and C-Bow side racks
The Hepco&Becker Sportrack supports a hard topcase, but, oddly, replaces the pillion seat. 5kg limit.
The C-Bow racks are normally for softbags only, but the the Orbits are lockable hardcases--the only such option I know for the RS. 3kg limit per side. Unfortunately, the loss of the pillion seat to also have a topcase is hard to take.
https://www.hepco-shop.de/meinbike/t...henhalter.html
https://www.hepco-shop.de/orbit-seitenkoffersatz-fuer-c-bow-traegers
https://www.motomachines.com/Hepco-B...er_p_6053.html
Kappa Rear rack for Monolock/Monokey cases and "Soft bag" holder
The rear rack appears to support a hard topcase with a 6kg limit. I can't find any pictures of the soft bag holder, but I assume it's similar to other ones on the market.
Kenma Ventura
The Ventura system includs side soft pannier racks and racks for soft top bags (with an option for a hard topcase). The topcase can be mounted 'backward' over the pillion seat or outward behind the seat.
https://www.ventura-mca.com/Street-Triple-765S-S-LAMS-R-RS
https://www.ventura-mca.com/Bonneville
https://www.ventura-bike.com/Astro-Top-Box-VTB1432-B
http://www.kenma.com.au/motorcycle_bags.html
Renntec Carrier
I believe Renntec's Carrier will fit their Renntec 28L topbox (or any soft top bag). The internet has evidence that a 48L topbox once existed, but it appears to no longer be sold. They appear to carry no sidecase options.
SW-Motech Alu-Rack and Blaze H saddlebags
It's surprisingly hard to find information on these. For the ALU-Rack, nobody is selling them for the 765, but a comment on Revzilla claims it's possible.
There aren't many dealers selling the Blaze specifically for the 765 either, but SW-Motech says they should fit.
https://www.revzilla.com/motorcycle/...675r-2013-2016
Potentially Compatible Street Triple 675 options
Givi sells the Easylock Saddlebags for the 675. No idea if they'd fit a 765.
The 675 luggage option I wish the 765 had is the Fehling Topcase Carrier and Case Holder. I emailed them a few months ago and they said they had no plans to make a version for the 765. I've never found a U.S. distributor, but there's a U.K. one here:
http://www.squaredeals-ltd.co.uk/str...de-28145-p.asp
http://www.squaredeals-ltd.co.uk/str...de-19316-p.asp
windyrun likes this.
deepfriedtank is offline
post #2 of 141 (permalink) Old 02-25-2018, 05:30 AM
Main Motorcycle: Street Triple 765R
Other Motorcycle: Suzuki DRZ400E
The SW-Motech Alu Rack does fit the 765. I have fitted one with the adaptor plate for a Givi top box that attaches with 1/4 turn Cam Locs.
DaytonaDave is offline
post #3 of 141 (permalink) Old 02-25-2018, 12:14 PM
Main Motorcycle: 2018 Street Triple R 765
Steaktastic's Avatar
The SW-Motech Blaze saddlebags fit the 765 as well, I installed these recently. Perfect for those who do occasional touring and don't want to have huge metal things handing off their bike. They come with drybags to protect the inside from moisture.
2018 Street Triple R 765 / 2015 Yamaha FZ-07 / 2007 Honda Shadow
Steaktastic is online now
post #4 of 141 (permalink) Old 02-25-2018, 11:09 PM
Main Motorcycle: Street Triple RS765
Another confirmation that the SW Motech bags that are for the 675 will fit the 765... have a set of them on my bike and they work a treat.
Current Bike: Triumph Street Triple 765 RS
Previous Bikes: Ducati 899 Panigale, Suzuki GSXR 750 L1, Suzuki GSXR 1000 K6, Suzuki GSXR 600 K4, Suzuki SV650, Suzuki Bandit 600, Moto Guzzi V50, Aprillia Pegaso 125, Yamaha SR125.
dawnrazor is offline
post #5 of 141 (permalink) Old 02-26-2018, 09:01 AM
tubi's Avatar
Can you send a photo?
Sent from my iPhone using Tapatalk
tubi is offline
post #6 of 141 (permalink) Old 02-26-2018, 09:08 PM
Here's the post where I put up a couple pics:
https://www.triumphrat.net/2003484434-post1334.html
post #7 of 141 (permalink) Old 02-27-2018, 08:03 AM
tubi's Avatar
thanks. your bike looks almost the same as mine ;-) sweet.
btw both Ventura and rennetec offer more weight limit than givi fittings (do not rember exactly but they offered more, like 1 or 2 kg). it seemed to me moneywise rennetec was better value than ventura (which is pretty hefty when buying entire set). do not know the givi details, but they are moslty reasonably priced.
SW motech alu rack is known to cause damage to subframe.
oyster bags of hepco becker are padlock lockable.
Givis easylock was confirmed in other posts not to fit 765.
tubi is offline
post #8 of 141 (permalink) Old 02-27-2018, 05:02 PM
Tubi,
You said "SW Motech alu rack is known to cause damage to subframe." I have not heard this on Street Triples do you have details ?
Speed Triples have had issues but the rack, attachment and sub frame are all completely different.
post #9 of 141 (permalink) Old 02-28-2018, 02:41 AM
tubi's Avatar
Could be. I am holding off from this rack.
tubi is offline
post #10 of 141 (permalink) Old 03-01-2018, 05:06 PM
Main Motorcycle: 2018 Street Tripls RS
Other Motorcycle: 2004 Ducati ST3
Extra Motorcycle: 2000 Ducati Monster
I just heard from Moto Machines, the US importer for Hepco & Becker, that the 765 C-Bow mounts should be available by the end of March.
MarioP is offline
New member gone from Street Triple R to Street Twin. First impressions review. bass_of_space Water Cooled Twins Talk 37 06-07-2017 02:28 AM
Speed Triple Luggage arobert3 Speed Triple Forum 12 06-06-2017 06:51 PM
Luggage Options Scotia Tiger 800 - 800XC Mods & Workshop 19 03-08-2016 01:43 PM
What are luggage options? RoadIII Speed Triple Forum 34 08-11-2015 08:08 AM
