2000 Sprint ST wonít start - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
post #1 of 31 (permalink) Old 10-09-2019, 06:20 PM Thread Starter
Jcaldwell's Avatar
So about a month ago my 2000 Triumph Sprint ST wasnít starting. Turns out I needed a new battery and a new solenoid. I replaced both but now when I go to start the bike all I get is a click and the headlights cut off when I press the starter button. Iím getting good voltage to the solenoid and itíll start if I short it with a screwdriver. The horn works and I canít seem to find where thereís a shortage in the wires IF thereís a shortage in the wires. Iím stuck on where to go from here. Any suggestions are greatly appreciated.
Jcaldwell is offline
post #2 of 31 (permalink) Old 10-11-2019, 12:37 AM
Have you checked fuses?
post #3 of 31 (permalink) Old 10-11-2019, 08:05 AM Thread Starter
Jcaldwell's Avatar
Yes I checked fuses
post #4 of 31 (permalink) Old 10-11-2019, 09:26 AM
Main Motorcycle: Sprint GT 2011 Blue
Seems that you have a problem w/ your clutch lever switch. Try to clean it first.
Do you actually see 12V on the solenoid command terminals when you press the start switch?
Fred
fredsprint is online now
post #5 of 31 (permalink) Old 10-11-2019, 05:29 PM Thread Starter
Jcaldwell's Avatar
Fred
Haven’t checked the clutch lever switch. When I check the voltages I get 12.4 on battery and solenoid terminals. When I press the starter switch voltages go up to 12.9 on the solenoid...no idea why it would increase.
post #6 of 31 (permalink) Old 10-12-2019, 03:57 AM
Main Motorcycle: Sprint ST1050
suggest you to check relays...
BigDen is offline
post #7 of 31 (permalink) Old 10-12-2019, 11:48 AM
Originally Posted by Jcaldwell View Post
Havenít checked the clutch lever switch. When I check the voltages I get 12.4 on battery and solenoid terminals. When I press the starter switch voltages go up to 12.9 on the solenoid...no idea why it would increase.
Isn't it because you lights are switched off?
I am speaking of the command pins. Not the switched pins regarding the voltage.
Fred
post #8 of 31 (permalink) Old 10-13-2019, 02:23 AM Thread Starter
Jcaldwell's Avatar
Checked the relays they all seem to be working
post #9 of 31 (permalink) Old 10-13-2019, 02:25 AM Thread Starter
Jcaldwell's Avatar
Fred
Yeah looks like I’m getting the right voltages and resistance everywhere. Checked the clutch switch and headlight cutout relay and those seem to be working fine. Makes sense why voltage increases with the headlights cutting out.
post #10 of 31 (permalink) Old 10-13-2019, 04:02 PM
well, you better to be 100% sure)
next step is solenoid relay
btw, your ST is 1050?
BigDen is offline
