VFR750 mirror swap - Triumph Forum: Triumph Rat Motorcycle Forums
 3Likes
  • 1 Post By DeusExMaxima
post #1 of 8 (permalink) Old 10-03-2019, 02:40 PM Thread Starter
Main Motorcycle: 1999 Sprint ST
Other Motorcycle: 1985 Honda Nighthawk 700S
Extra Motorcycle: 88 Ninja 750R cafe racer
VFR750 mirror swap
I have a 99 Sprint ST. I read about VFR800 mirrors swapping on to a Sprint. Everyone knows about the droopy Triumph factory mirrors with the fugly condom wrapped around the mirror shaft. I happen to have a 97 VFR750 laying around and wondered if those mirrors would fit. After reading the VFR800 swap thread, I noticed that the 750 mirrors appeared very similar to the 800 mirrors. The mirrors I had looked to be in decent shape except with a bit of scuffing underneath the housing.
I saw that the bolt spacing was about 2mm wider for the Triumph mirrors, than the 750 mirrors. A bit of dremeling later, and I had the bolt holes match the Triumph bolt pattern for the 750 mirrors. I used the 750 rubber pad and got both mirrors to securely fasten to the Triumph. The mirror part is about the same size on both mirrors, but the stalk is sleeker on the 750 mirror. The 750 mirrors do not move at all. Also, the 750 mirrors do not extend out as far, by about 2 inches on each side, effectively narrowing the bike by 4 inches total.
These are the mirrors that Triumph should have used on the bike. Im very pleased with the result. Id post pics but I dont know how to post them since the Photobucket fiasco, and they look just like the VFR800 mirrors.
tylercraige likes this.
IBA #54915
DeusExMaxima is offline
post #2 of 8 (permalink) Old 10-03-2019, 06:50 PM Thread Starter
Here are some pics:
ID:	657514   Click image for larger version
BRG-BIRD likes this.
IBA #54915
post #3 of 8 (permalink) Old 10-03-2019, 07:19 PM
Main Motorcycle: 1996 Thunderbird
BRG-BIRD's Avatar
Other Motorcycle: 2009 Moto Guzzi Norge
Extra Motorcycle: 1975 Honda CB550F
Looks great, I did the same VFR mirror swap on my 2000 Sprint and it was well worth the effort
"You are either onto something or on something"........The Common Man
“Sometimes you are best off dealing with the Devil you know” anonymous
BRG-BIRD is offline
post #4 of 8 (permalink) Old 10-04-2019, 11:08 AM
Main Motorcycle: 2003 Sprintabusa ST
Mile High Moderator
MileHighScottie's Avatar
Other Motorcycle: 2016 Speed Triple
Extra Motorcycle: 2003 Sprint ST - Sapphire
Love my VFR mirror swap on both Sprints. They also don't vibrate nearly as much as the Triumph mirrors
Sent from my SM-G950U using Tapatalk
-- Scott
I probably need an intervention because of the bikes that keep 'following' me home. Current garage:
2001 Daytona 955i, 2 yes two, 2003 Sprint 955i STs (spouse rides one), 2016 Speed Triple, 2001 Kawasaki ZRX 1200R
MileHighScottie is offline
post #5 of 8 (permalink) Old 10-04-2019, 02:38 PM Thread Starter
Did you guys use VFR800 mirrors or 750 mirrors?
IBA #54915
post #6 of 8 (permalink) Old 10-04-2019, 04:56 PM
Mile High Moderator
Deus, I have VFR800 mirrors on my bikes. Both work.
-- Scott
post #7 of 8 (permalink) Old 10-04-2019, 09:42 PM
BRG-BIRD's Avatar
I used the VFR800 mirrors
BRG-BIRD is offline
post #8 of 8 (permalink) Old 10-16-2019, 05:05 PM Thread Starter
Heres a better pic of the VFR750 mirrors installed. They are very solid at all speeds.
IBA #54915
