Coolant leak - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
post #1 of 12 (permalink) Old 09-18-2019, 11:16 PM Thread Starter
Main Motorcycle: MV agusta f4 senna
Other Motorcycle: Triumph sprint GT, Buell
Coolant leak
Quick question as far as a possible leak on my 2011 GT. She's at 74k miles and running well but last week I noticed some coolant on the floor and there was a few drops sitting on top of the water pump. I thought maybe the hose clamp was a little loose and snugged that down. Noticed it again and seemed to drip down from inside of the left fairing. I pulled the fairing and don't see any obvious source. I was wondering if there were any suspects that would be a source or is the water pump on its way out?
Otherwise the bike is running fine and is not overheating or anything like that.
tommymac is offline
post #2 of 12 (permalink) Old 09-19-2019, 04:38 AM
Main Motorcycle: Sprint GT 2011 Blue
You have to determine whether it's close to the water pump (which would be shot), or the radiator cap, or the overflow tank.
You said you saw water on the TOP of the water pump. If the pump were leaking the coolant would drop below the pump.
I would run the bike w/o the left fairing and try to source the leak. For instance you would be able to see whether the overflow tank is getting full when hot.
Fred
fredsprint is online now
post #3 of 12 (permalink) Old 09-19-2019, 06:29 PM
Main Motorcycle: 1996 Thunderbird
BRG-BIRD's Avatar
Other Motorcycle: 2009 Moto Guzzi Norge
Extra Motorcycle: 1975 Honda CB550F
I had a 2000 Sprint ST through an unfortunate tip over in the driveway turned into a somewhat fortunate event as I discovered a coolant leak during disassembly of the fairings. It was difficult to figure out where the leak was so I let it run in the garage while I mowed. Turns out the coolant was leaking through the ends of the hose, through the webbing. Weird. Yours may not be doing this but something to look at as a possibility.
"You are either onto something or on something"........The Common Man
“Sometimes you are best off dealing with the Devil you know” anonymous
BRG-BIRD is offline
post #4 of 12 (permalink) Old 09-20-2019, 09:35 AM
Main Motorcycle: 2018 Kawasaki H2 SX SE
champ87's Avatar
Other Motorcycle: 1973 Yamaha RD350
Extra Motorcycle: 1974 Kawasaki 500 H1E
On the bottom side of the water pump there's a small hole. When coolant drips out there it's a sign that the shaft seal is leaking. Unfortunately, the pump isn't designed to allow seal replacement so it's usually a pump replacement. I replaced mine at 49K miles.
See this post
Like fredsprint, I'm a bit thrown by your report of drops of coolant sitting on top of the pump but still take a look with the engine running and see if you can spot any drips of coolant coming out of that hole.
Champ87
It's amazing how fast you can go when you take your time.
champ87 is offline
post #5 of 12 (permalink) Old 09-20-2019, 11:26 PM Thread Starter
I have been riding the bike to work about 38 miles each way, the last few days and when I get home I throw a towel down to catch anything and haven't seen anything. Given the mileage I am at and am almost due for an oil change I am leaning towards swapping out the pump anyway. I couldn't find any obvious source of a leak further up in the engine.
tommymac is offline
post #6 of 12 (permalink) Old 09-22-2019, 09:36 AM
Main Motorcycle: '15 Street Triple R
Extra Motorcycle: '70 Husq 360 cross
With a cold engine. An easy way to check if the water pump is leaking is to take a Q-tip liberally swabbed with Vaseline and push it into the water pump vent hole, to act as a plug. Leave it set overnight, remove it the next morning and coolant will flow if the pump is leaking.
Metallion likes this.
Bruce C is online now
post #7 of 12 (permalink) Old 09-23-2019, 05:38 PM Thread Starter
I noticed the inside of the fairing was a little damp again and seems to be right where the weep hole is located. Ordered a new water pump and will hopefully get that doen with my oil change next week
tommymac is offline
post #8 of 12 (permalink) Old 09-24-2019, 10:33 AM
Main Motorcycle: 2011 Triumph Sprint GT
Other Motorcycle: 2016 Yamaha FJ-09
Extra Motorcycle: 2002 BUELL S3T Thunderbol
When i first bought my 11 Sprint GT at just under 11K i noticed it had a slight coolant leak and the level in the recovery tank was low. It turns out that the clamp at the top of the coolant hose above the water pump was loose. Coolant was trickling down the back of the hose and resting on top of the water pump. Your bike has many more miles than mine did so it's entirely possible that your water pump has failed but it may be worth checking. I was relieved that it was that simple of a remedy to tighten the clamp. Hope you get it sorted out.
Metallion is offline
post #9 of 12 (permalink) Old 10-12-2019, 06:20 PM Thread Starter
So I replaced the pump, and I think its bad. I rode it to work once, 78 miles round trip and noticed a stain on the driveway the next morning. Tried to ride in yesterday and made a pit stop and noted coolant pouring out. So today I got the fairing off and noted after running for a minute coolant is pouring out of the weep hole. It was installed as per the instructions in the shop manual and was a rather easy job. Is this that they sent me a bad pump or is there something else I am missing.
tommymac is offline
post #10 of 12 (permalink) Old 10-13-2019, 01:56 PM
Main Motorcycle: 2013 TTSE
pf flyers's Avatar
Very possible you got a bad pump
Sent from my SM-G900T using Tapatalk
pf flyers is offline
