ST 1050 Clutch - Triumph Forum: Triumph Rat Motorcycle Forums
 9Likes
post #1 of 13 (permalink) Old 09-15-2019, 08:04 AM Thread Starter
Main Motorcycle: 2001 Legend TT
Other Motorcycle: 2009 Sprint ST 1050
ST 1050 Clutch
Afternoon all.
New to Sprints (also have a Legend), so excuse the ignorance!
After having the fork seals done under warranty at the dealership (where I bought the bike, some 90miles away) I noticed the clutch cable was fouling the ignition key - due to the cable being incorrectly routed in front of the fork. Disappointed in the dealership but hey ho. Easy enough to sort I thought. Following the workshop manual (except for disconnecting the battery) I loosened the locknuts at the clutch end to allow the inner cable to be disconnected at the clutch end, then disconnected the inner cable at the clutch lever end. Rerouted the cable behind the fork leg, loosely connect the inner cable at the lever end, and then connected back up at the clutch end. Adjusted to 3mm play at the lever end, tightened the lock nuts at both ends. So far so good. 3mm play set at lever. Went to start it, and no joy!? I'm guessing it is the switch at the lever, however it looks to be free and moving, and the lever closes fully to the grip. I've squirted a touch of WD40 in, but still no luck starting it.
Does anyone have any tips, experience, or thoughts that might solve the problem? Any advice gratefully received!
Thanks, Ben.
Oneear is offline
post #2 of 13 (permalink) Old 09-15-2019, 10:22 AM Thread Starter
Further update: I've removed the clutch lever by taking the pivot pin out, so as to ensure the clutch switch is fully out (therefore in the correct position to enable the starter circuit) and still nothing. Ignition as usual - needles sweep, headlamps on, dash lights all okay, no click from the solenoid/starter. More confusion!
Oneear is offline
post #3 of 13 (permalink) Old 09-15-2019, 10:32 AM
Main Motorcycle: Daytona 675R
CafRacer's Avatar
Other Motorcycle: Thruxton R
Make sure you haven't accidentally operated the Killswitch, is the fuel pump running?
Normally you can hear or feel a small click as you operate the clutch switch manually, if it feels ok check the wires going into the switch they may have been strained while they were removing the forks or when you moved the cable.
Oneear likes this.
CafRacer is online now
post #4 of 13 (permalink) Old 09-15-2019, 11:55 AM Thread Starter
Hi Scotty,
Yeah, can hear the fuel pump kick in and prime the system. Had a look at the two wires running into the back of the switch and they're secure. Thanks for the reply!
Oneear is offline
post #5 of 13 (permalink) Old 09-15-2019, 03:29 PM
CafRacer's Avatar
Originally Posted by Oneear View Post
Hi Scotty,
I presume it was starting ok immediately before you rerouted the clutch cable?
if that is the case then the clutch switch is obviously still the favorite, presume it's in neutral so side stand switch is out of the equation?
Sorry if some of these suggestions sound dumb but I've learnt over many years not to ignore the simple things first.
Oneear likes this.
post #6 of 13 (permalink) Old 09-15-2019, 04:05 PM Thread Starter
It was starting okay the day before, certainly, and I haven't had a problem starting it in the three weeks I've had the bike.
It's showing neutral light as lit up. Would pulling the wiring from the switch effectively bypass it, or should I bridge the two wires to enable to starter circuit to operate. That would at least confirm it was the switch or otherwise (in my head anyhow!)
Cheers again!
Oneear is offline
post #7 of 13 (permalink) Old 09-15-2019, 05:11 PM
CafRacer's Avatar
I presume it's on little spade connectors then and it's not a sealed unit, if you don't have a multimeter to test it then try starting it with them disconnected and then shorted together, not sure if it's normally open or closed with the clutch lever pulled in.
I would imagine the switch would be closed with the lever pulled as a failsafe in case of a wiring fault.
Other than that it's the usual things, starting with the battery.
Oneear likes this.
post #8 of 13 (permalink) Old 09-15-2019, 05:27 PM Thread Starter
Yep, little spades. Will give it a go in the morning, and see what occurs. Fingers crossed. Cheers.
Oneear is offline
post #9 of 13 (permalink) Old 09-15-2019, 05:29 PM
Main Motorcycle: 02 Sprint RS
Steve Ford's Avatar
Other Motorcycle: 06 Tiger
Extra Motorcycle: a few others
I had basically the same thing happen the other day on my GT.
It was the battery dying under load but at least I got a click and a spin from the starter.
New Yuasa battery and it fires right up.
If I'm not mistaken they did something weird with the ECM and you can't just bypass the clutch switch without killing the fuel level reading. The way they wired it up I don't think it'll be too easy to jump on the 1050. Just an aggravating design.
Oneear likes this.
Steve Ford is online now
post #10 of 13 (permalink) Old 09-15-2019, 08:33 PM
Main Motorcycle: 2006 Sprint ST 1050
Stevienh's Avatar
Other Motorcycle: 2009 BMW R1200R
Extra Motorcycle: Son's 2010 Street Triple
There is an electrical junction in the clutch safety switch wiring a few inches from the clutch lever. I had an intermittent connection there that would prevent the starter from working. With the manipulation you did, maybe that connection has been broken.
Oneear likes this.
Stevienh is offline
