Rear Brake Pedal Adjustment - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 3 (permalink) Old 04-19-2019, 07:14 AM Thread Starter
Morning all,and Happy Easter.
I wish to lower the Rear Brake Pedal (Sprint GT). I have managed to loosen off the pushrod upper locknut which was very tight but the lower locknut is trapped inside the forked clevis and is therefore impossible to turn. Question, is it permissible to revolve the pushrod to attain the required adjustment.
Thanks.
Our Gee is offline
post #2 of 3 (permalink) Old 04-19-2019, 11:50 AM
Main Motorcycle: 2003 Sprintabusa ST
Mile High Moderator
MileHighScottie's Avatar
Other Motorcycle: 2016 Speed Triple
Extra Motorcycle: 2003 Sprint ST - Sapphire
If it will do it, and you can secure it afterwards.
Sent from my SM-G950U using Tapatalk
-- Scott
I probably need an intervention because of the bikes that keep 'following' me home. Current garage:
2001 Daytona 955i, 2 yes two, 2003 Sprint 955i STs (spouse rides one), 2016 Speed Triple, 2001 Kawasaki ZRX 1200R
MileHighScottie is offline
post #3 of 3 (permalink) Old 04-20-2019, 12:58 AM Thread Starter
Problem solved,
Little bit of lateral thinking. Loosen the upper locknut to gain the required pedal position, remove the Clevis Pin retaining clip and the Pin. The Pushrod assembly can now be pushed up to snug against the repositioned upper locknut. Refit the Pin and Retaining Clip.
Our Gee is offline
Alternatives to T140 brake master cylinders? [email protected] Classic, Vintage & Veteran 61 06-26-2019 04:16 PM
Bigger pad on rear brake pedal saltrax Cruisers - America, Speedmaster 2 04-23-2013 01:19 AM
More adjustment for rear brake pedal T100? Taxbiker Air Cooled Twins Technical Talk 0 07-31-2012 10:55 AM
T100 Rear Brake Pedal Adjustment McBike Air Cooled Twins Technical Talk 6 10-13-2008 07:36 PM
Suspension Setup - Step by Step Sparti Speed Triple Forum 11 05-28-2006 02:33 AM
