Idle speed - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 2 (permalink) Old 04-18-2019, 03:48 AM Thread Starter
Main Motorcycle: 2001 SPRINT ST
Duckadiledundee's Avatar
Idle speed
According to the Haynes manual the idle speed on my 2001 sprint st 955i should be 1200rpm ( mine bounces between 0-500)...it explains why I’m cutting out all the time when pulling up and having to stop.. it also states that the idle air control valve cannot be adjusted manually???...
Is this an expensive take it into a triumph dealers to sort it out job or can I really just turn a screw and job done...
Duckadiledundee is offline
post #2 of 2 (permalink) Old 04-20-2019, 08:59 AM
Main Motorcycle: Sprint GT 2011 Blue
What said the manual is very clear (and true).
You need TuneECU plus the fiting cable.
You also may have to check that none of the vacuum tube is clogged and maybe balance the throttle. Usually the iacv figure as seen w/ tuneEcu shoild be around 35 (AFAIR). It's supposed to be self adjusted to reach the correct idle speed though.
So it may be that the throttlebody butterflies are too close. At idle.as opposed to post 2002 the throttlebody that havebypass screws, your's must be adjusted by changing the butterfly offset between cyl 1/2 and 2/3.
Should be documented in haynes as well.
Fred
fredsprint is offline
2016 STR or wait for the rumored 800 in 2017? eric nyc Street Triple Forum 199 12-21-2016 02:52 PM
Idle speed slow to return KaHOnas Sprint Forum 17 03-10-2014 02:26 PM
Low idle speed kubbie Triumph SuperSports 5 08-25-2009 09:57 AM
Haynes manual idle speed Speedmaster07 Air Cooled Twins Technical Talk 10 04-08-2008 02:15 AM
Crashing ExPatTommo Speed Triple Forum 15 05-08-2007 09:33 AM
