955 Sprint Head with Tiger Pistons - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 17 (permalink) Old 04-14-2019, 01:43 PM Thread Starter
Main Motorcycle: 02 Sprint RS
Steve Ford's Avatar
Other Motorcycle: 06 Tiger
Extra Motorcycle: a few others
Doing a little research shows that an 03 ST and 06 955 Tiger have the same crankshaft but different pistons.
Does anyone know what the compression ratio would be if you use the stock Tiger pistons with a Sprint head?
I'm thinking of a possible mix and match motor but I may need to swap out the pistons as well.
Steve Ford is offline
post #2 of 17 (permalink) Old 04-14-2019, 02:49 PM
Main Motorcycle: 2003 Sprintabusa ST
Mile High Moderator
MileHighScottie's Avatar
Other Motorcycle: 2016 Speed Triple
Extra Motorcycle: 2003 Sprint ST - Sapphire
Did you cross post this to the Tiger group? You may get better answers since you're trying to swap into a Tiger
Sent from my SM-G950U using Tapatalk
-- Scott
I probably need an intervention because of the bikes that keep 'following' me home
MileHighScottie is offline
post #3 of 17 (permalink) Old 04-14-2019, 03:05 PM
Main Motorcycle: Sprint GT 2011 Blue
The tiger is rated 11.6:1 while the sprint is rated 12:1. (Plus camshafts are different BTW).
Fred
fredsprint is offline
post #4 of 17 (permalink) Old 04-14-2019, 03:59 PM Thread Starter
Steve Ford's Avatar
Thank you, I know that part of it.
What I don't know is what kind of compression ratio I'll wind up with with the mismatched pistons and combustion chambers.
I don't want to build a grenade or wind up with a dog.
I'll try the Tiger Section as well, someone must have done this before.
post #5 of 17 (permalink) Old 04-14-2019, 07:26 PM
Main Motorcycle: 2017 Speed Triple
jer5ak's Avatar
Other Motorcycle: 1985 Suzuki 1150
Extra Motorcycle: 2002 Triumph ST
For the CR you need to measure how far in the barrel the pistons are and if the pistons are domed,dished or flat top. The closer to the deck they are the higher the CR. Donít forget the piston to valve clearance .
When all else fails, get a bigger hammer!
jer5ak is offline
post #6 of 17 (permalink) Old 04-14-2019, 07:47 PM Thread Starter
Steve Ford's Avatar
I put an inquiry into Triumph America to see if anyone there would be able to give me a number, we'll see.
I'm pretty sure the thing to do is pistons/heads/cams/fuel rail/injectors.
It might be easier to just stick in the Sprint motor, change out the fuel rail and live with the up for first on the left hand side.
post #7 of 17 (permalink) Old 04-14-2019, 10:36 PM
Mile High Moderator
Might be your best option bud
-- Scott
post #8 of 17 (permalink) Old 04-15-2019, 07:49 AM
Main Motorcycle: 2011 Sprint GT
KaptainRat's Avatar
Other Motorcycle: Yamaha XJ 650 (Restoring)
Extra Motorcycle: Bultaco Sherpa T 360
I did the swap when the middle of a spark plug let go and fell into the cylinder head of my 99 Tiger. Made a hell of a mess. You get used to the race pattern 1 up 5 down gear change. Just remember head down to go fast, head up to slow down.
Cheers,
Kap.
2011 Sprint GT - Pacific Blue with Carbon Fibre front guard, Trident stuby exhaust, Radguard radiator protector, Geelong carbon fibre tank protector, R&G frame sliders and rim stickers.
KaptainRat is offline
post #9 of 17 (permalink) Old 04-15-2019, 02:01 PM
Sorry Steve we misunderstand each other.
If the crank shaft is the same then the displacement is the same. So the only thing that changes is the piston. So if you put tiger pistons you'll get tiger ratio.
Does it sound reasonable or do I miss the obvious?
Edit: it seems that the obvious is that the head is not the same either .
Fred
post #10 of 17 (permalink) Old 04-15-2019, 05:49 PM Thread Starter
Steve Ford's Avatar
You miss the obvious.
The question is what would the compression ratio be using Tiger pistons with a Sprint head?
Not Tiger piston/Tiger head
Not Sprint piston/Sprint head but
Tiger piston/Sprint head.
It doesn't appear as if anyone has the answer at hand SO I'm going to stick the Sprint motor in the Tiger and then pull apart/repair the Tiger motor and stick it on the bench for a rainy day.
Compatability Guide 1050 09 sprint parts to 955 04 armarra Maintenance Tips and Tricks for your Sprint 14 07-09-2016 03:31 AM
Torquing and re-torquing the head on a 955 KitNYC Sprint Forum 0 12-04-2013 01:40 AM
2006 955 vs new tiger 800 cjmadura Tiger Chat 19 09-03-2012 07:08 PM
Still loving my '00 Sprint - no reason to upgrade yet. ExKellick Sprint Forum 16 10-23-2007 02:15 PM
Sprint ST and the new Tiger Kirk Sprint Forum 5 05-13-2004 02:08 AM
