Scottoiler removal??? - Triumph Forum: Triumph Rat Motorcycle Forums
 2Likes
post #1 of 18 (permalink) Old 04-10-2019, 08:02 AM Thread Starter
Main Motorcycle: 2001 SPRINT ST
Duckadiledundee's Avatar
Discovered what I believe to be a Scottoiler pipe peeping out from chain guard...if not in use would this have a negative effect on bike such as moisture getting into the engine,rough running when cold and having to give a few extra revs when starting up in morning to prevent it cutting out...should I remove it and cap off or replace t- valve on vacuum pipe???
Duckadiledundee is offline
post #2 of 18 (permalink) Old 04-10-2019, 10:05 AM Thread Starter
Its ok its coming off...potential problems solved..
post #3 of 18 (permalink) Old 04-10-2019, 03:38 PM
Main Motorcycle: 2003 Sprintabusa ST
Mile High Moderator
MileHighScottie's Avatar
Other Motorcycle: 2016 Speed Triple
Extra Motorcycle: 2003 Sprint ST - Sapphire
Isn't the Scottoiler vacuum-actuated? Therefore, if the bike isn't running, no oiling. I highly doubt it would backflow either.
-- Scott
I probably need an intervention because of the bikes that keep 'following' me home. Current garage:
2001 Daytona 955i, 2 yes two, 2003 Sprint 955i STs (spouse rides one), 2016 Speed Triple, 2001 Kawasaki ZRX 1200R
MileHighScottie is online now
post #4 of 18 (permalink) Old 04-10-2019, 04:28 PM Thread Starter
Thank you mile high Scottie...new to bikes and kinda grasping at straws as to why it’s running a bit on the rough side...
post #5 of 18 (permalink) Old 04-10-2019, 10:04 PM
Mile High Moderator
Can you get a video of the engine running rough?
Sent from my SM-G950U using Tapatalk
-- Scott
post #6 of 18 (permalink) Old 04-11-2019, 02:05 AM Thread Starter
I can mate but not until tomorrow as working long shift..thinking about Ecu tuning or remapping ( I don’t know the difference)...I’ve changed plugs oil/ air filter and put nice new oil in...going to bang some redex in to clean fuel lines and such but other than that I don’t know what to do...not sure if taking it for ecu malarkey is the answer if I need to do other stuff first...
post #7 of 18 (permalink) Old 04-11-2019, 02:54 AM
Main Motorcycle: Sprint GT 2011 Blue
Please fill out your profile so that we can know what bike you have.
Fred
fredsprint is offline
post #8 of 18 (permalink) Old 04-12-2019, 12:55 PM Thread Starter
Oops...tried to remove original post and all I’ve done is report myself..apologies to admin..
post #9 of 18 (permalink) Old 04-12-2019, 04:19 PM
Mile High Moderator
It's all good.
-- Scott
post #10 of 18 (permalink) Old 04-12-2019, 05:12 PM
Supernova
Main Motorcycle: 2011 Sprint GT 1050
DaveM's Avatar
Other Motorcycle: 2004 Daytona 955i
Extra Motorcycle: Previously - Many
Thumbs up Welcome
Welcome aboard Duck, great forum, plenty of knowledgeable types (not me) and a lot of threads with answers to you questions already in here.
cheers
DaveM
DaveM is offline
Scottoiler Summary Please? (EFI) Zalman Air Cooled Twins Technical Talk 23 05-04-2015 01:25 PM
2009 Speedmaster AI removal kit for dummies Kastun27 The Welcome Center 8 02-12-2014 07:19 PM
Great source of info - Links to maintenance, tuning, modifications and so on Haggis Air Cooled Twins Technical Talk 28 08-10-2013 09:22 AM
Front Wheel Removal Ecaz Air Cooled Twins Technical Talk 2 07-29-2012 05:17 PM
Scottoiler Install Gary_spain Air Cooled Twins Technical Talk 9 12-25-2011 03:28 PM
