Broken coolant reservoir overflow tube help needed! - Triumph Forum: Triumph Rat Motorcycle Forums
 8Likes
post #1 of 34 (permalink) Old 02-16-2018, 03:19 PM Thread Starter
Main Motorcycle: 2001 Sprint ST 955i
Argh!!
Upon inspecting the coolant overflow tank due to rusty paste contaminating the interior of it I broke the nozzle on the upper overflow (return?l hose. Found a replacement tank with hoses on eBay since the dealer doesn't carry them anymore due to being older than 10 years. Yay.
Will any kind of tape make for a temporary fix until the replacement arrives? The break is where the square part meets the nozzle cylinder.
riddmkidd is offline
post #2 of 34 (permalink) Old 02-16-2018, 03:20 PM Thread Starter
would crazy glue work?
post #3 of 34 (permalink) Old 02-16-2018, 04:03 PM
Main Motorcycle: '03 Sprint ST
pushr0d's Avatar
Other Motorcycle: 2000 Sprint ST (wrecked)
Extra Motorcycle: 1988 FXR Lowrider (sold)
Yeah, they're bad about that. Most common way to break them is when you put that side fairing back on.
I don't think you can repair that fitting - it's injection molded plastic ("nylon"), and really old. I replaced mine years ago with a similar-looking item from a laboratory kit.
Until you find a replacement, you can use a longer tube that curves into the bottom of the tank, and then put some silicone caulk or some other flexible gunk at the tank penetration.
You might find a 90 tubing connection at the local auto parts store. Here's the Grainger page: https://www.grainger.com/category/ba...ecatalog/N-qvx.
It's not a critical break - it's the radiator 'overflow' hose, so there's no pressure on it. Sealing the hole just helps keep the leaking to a minimum. The end of the hose must remain at the bottom-ish of the tank, though.
riddmkidd likes this.
pushr0d is online now
post #4 of 34 (permalink) Old 02-16-2018, 05:44 PM
Main Motorcycle: 02 Sprint RS
Steve Ford's Avatar
Other Motorcycle: 06 Tiger
Extra Motorcycle: a few others
Take the old one with you into a hardware store.
They'll have a brass replacement for around two bucks in the plumbing section.
KitNYC and riddmkidd like this.
Steve Ford is offline
post #5 of 34 (permalink) Old 02-16-2018, 11:27 PM
Main Motorcycle: Black '04 Sprint RS
TE Lifetime Contributor
KitNYC's Avatar
Other Motorcycle: Blue '04 Sprint RS
What Steve said. The brass won't break like the plastic. There's a separate hose that goes to the bottom of the tank from the end of the elbow inside the tank.
Cheers,
-Kit
'04 Sprint RS * Penske 8983 * Traxxion AK20s * Zero Gravity sport touring screen * Oxford heated grips * DGD keyless ignition * Relocated seat lock * Givi saddlebags with custom mounts * Fuzeblocks FZ-1 power block * Adaptiv TPX radar detector * Garmin GPS in RAM Aquabox * Garage door remote * Tokico six pots * Pazzo shorty levers * Voltmeter * Yoyodyne gas cap
KitNYC is offline
post #6 of 34 (permalink) Old 02-17-2018, 02:24 AM Thread Starter
Ooh the brass fitting is a great idea. I'm hoping needle nose pliers will get the elbow out. Sorting it out tomorrow. Hopefully my truck battery is recharged as well so I can actually get to the hardware store. It's been a week....
post #7 of 34 (permalink) Old 02-17-2018, 08:23 PM
KitNYC's Avatar
FWIW, that hose is not a deal killer for riding short distances.
Cheers,
-Kit
KitNYC is offline
post #8 of 34 (permalink) Old 02-18-2018, 12:19 AM Thread Starter
Thank for the assurance, I'm hoping it'll hold out until the replacement comes Friday.
post #9 of 34 (permalink) Old 02-19-2018, 06:17 PM Thread Starter
the service manual recommends using a handheld vacuum pump to "syphon the coolant through the system" so that the coolat passes through the cylinder and not just from the filler opening on the other side of the thermostat.
i have a speed bleeder that i use for my brake lines. is there any problem with residual brake fluid getting in the coolant lines by using it?
i'm more concerned now about the fluid leaking from my hoses like in the photos. the larger coolant hose seems to be swelling slightly at the clamp. time for replacements or will a thorough system flush be enough?
ID:	566650   Click image for larger version
ID:	566658   Click image for larger version
post #10 of 34 (permalink) Old 02-20-2018, 01:49 AM
KitNYC's Avatar
The hoses are spec'ed for replacement every two years, IIRC. Maybe every four. Silicone hoses last much, much, longer. These AS3 hoses are what I run.
Cheers,
-Kit
KitNYC is offline
Coolant Leak - advice needed s7paul Sprint Forum 16 06-22-2017 11:03 AM
Is it okay to leave the coolant overflow hose on top of this? rook2pawn Sprint Forum 3 03-30-2017 05:33 AM
Kind of a loose fit on replacement gasket for coolant overflow tank rook2pawn Sprint Forum 2 03-02-2017 08:55 PM
Coolant leak and MAP sensor tube pete des Thunderbird Cruiser Chat 2 06-13-2016 09:27 AM
2012 Street Triple Coolant Overflow Tank Gurgling Sound kensington Street Triple Forum 11 10-15-2015 03:40 PM
