Setting the Idle Air Control Valve - Page 4 - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
post #31 of 33 (permalink) Old 07-12-2019, 03:35 AM
Supernova
DEcosse's Avatar
Originally Posted by Steve Ford View Post
There's just an O-ring on the piston ... .
Don't believe there is any o-ring on the piston
@chickenstrip - maybe you just need to start by explaining your problem
DEcosse is online now
post #32 of 33 (permalink) Old 07-12-2019, 05:08 AM
Main Motorcycle: 02 Sprint RS
Steve Ford's Avatar
Other Motorcycle: 06 Tiger
Extra Motorcycle: a few others
Come to think of it, you're right, there's no O-ring.
It went the way of all flesh a long time ago.
Steve Ford is online now
post #33 of 33 (permalink) Old 07-12-2019, 08:29 PM
Main Motorcycle: 2002 Sprint RS
chickenstrip's Avatar
Thanks for chiming in Steve and DEcosse.
I got that notion from this thread.
6. Remove and save the o-ring on the stepper motor. Inspect the stepper motor plunger for carbon and/or oil buildup and dirt. You can use carb-choke cleaner to clean things off, or put some brake cleaner on a lint-free rag. Blow off the plunger well with air, making sure it's dry. Blow out the electrical connector. If excessive oil was on the plunger or case, you'll want to remove the vacuum lines from the throttle bodies and blow them out with carb-choke cleaner and air.
I've never dug into the ISCV (IACV - why did they change the name?) before and I haven't a pic to show me what the innards look like, so I'm poking in the dark.
Symptoms: Idle is at about 900 rpm - quite anemic, so I find myself 'nursing' the throttle to ensure it doesn't stall, which it does occasionally.
I've tried some easy-to-do possible fixes: cleaning the injectors with Techron and replacing the cracked ISCV hoses. The latter had me thinking that I solved the problem as the engine idles at 1200rpm for a minute or two, but then returns to the low idle.
So I was thinking the next step would be to check out the ISVC stepper since I've read that that solved the problem for some, and do a TBS while I'm at it - made a nice DIY manometer yesterday.
I'm happy to hear suggestions.
2002 Sprint RS: TOR silencer, LSL bars, Laminar lip, factory tail rack with Givi top box, custom painted OEM panniers (one of 'em anyway - sad story), M-Factory lowered pegs, Penske shock.Thanks for all the help, Kit!
chickenstrip is offline
Idle Air Control Valve? JayCee Tiger Workshop (archive) 4 10-20-2007 05:32 AM
Has anyone tested their idle air control valve? CharlestonRider Sprint Forum 3 07-27-2006 10:25 AM
Need help with Idle Air Control Valve 99TIGER Tiger Workshop (archive) 2 07-21-2006 09:59 AM
Idle Air Control Valve lesterg Daytona Deliberations 4 07-18-2006 07:02 AM
Idle air control valve dcorbell Speed Triple Forum 0 06-09-2006 12:07 PM
