Gas Tank Removal question - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
post #1 of 19 (permalink) Old 07-06-2010, 11:56 AM Thread Starter
Main Motorcycle: '05 Sprint ST, Blue
Clegg's Avatar
Other Motorcycle: '09 Ninja 250R (Sold)
Hey guys,
Now I've read many threads on here about gas tank removal, but there are some lingering questions I havent seen clearly answered or I saw conflicting answers:
1. The QD for the fuel fitting under the tank... is that a self sealing plug? As in - if I pull the QD off does the fuel shut at the tank side on its own?
2. And if #1 is 'no' what do you guys do for a process to remove all the fuel from the tank before pulling the QD off?
Just trying to get the process down before I pull the tank in the next couple days to do some maint. I would prefer not spilling 4Gal of gas all over the floor
Thanks,
Clegg is offline
post #2 of 19 (permalink) Old 07-06-2010, 09:40 PM
Main Motorcycle: 2018 Kawasaki H2 SX SE
champ87's Avatar
Other Motorcycle: 1973 Yamaha RD350
Extra Motorcycle: 1974 Kawasaki 500 H1E
Yes, but you still get a few drips of fuel so the usual fire hazard precautions apply. Make sure you press firmly on the release tabs to disconnect or you may break the plastic fittings.
Champ87
It's amazing how fast you can go when you take your time.
champ87 is offline
post #3 of 19 (permalink) Old 07-07-2010, 05:28 AM
Main Motorcycle: Sprint RS 2001 Yellow
Wodenborn1's Avatar
Other Motorcycle: Yamaha XS 750 D
Extra Motorcycle: Honda CD 185
Hi
Tank is allegedly self sealing
my process for removal first time
1. first take a photo with the digi camera - always advisable
2. label the pipes and outlets on the tank with a dymo labelmaker or somesuch - A to A, B to B etc
3. put new O ring washers in when refitting the tank
cheers
Chris
Wodenborn1 is offline
post #4 of 19 (permalink) Old 07-07-2010, 09:22 AM
steves's Avatar
The fuel pump is inside the tank, and depressurizes when you turn the bike off. There should only be a few drops of fuel in the line when disconnected.
I highly recommend securing the fittings before re-assembly. See my thread: https://www.triumphrat.net/sprint-for...sed-on-me.html
08 Sprint ST ABS
steves is offline
post #5 of 19 (permalink) Old 07-07-2010, 10:24 AM
Main Motorcycle: 06 ST, BOTM, 09-10 BOTY
oldndumb's Avatar
Other Motorcycle: 05SV1K, 2012 Ducati M1100
Originally Posted by Wodenborn1 View Post
Hi
cheers
Chris
No harm to do this, but unnecessary unless there is an indication that the O rings have been damaged.
Oldndumb
Caveat lector
oldndumb is offline
post #6 of 19 (permalink) Old 07-07-2010, 11:20 AM Thread Starter
Clegg's Avatar
Great info guys! Thanks as always!
The QD seems similar to most automotive fuel line clips, and I've done tons of fuel filter replacements on my cars. So shouldnt be that big of a deal.
The labling of the hoses and fittings is a solid plan... I've been burned on cars with that kind of mess up in the past.
Clegg is offline
post #7 of 19 (permalink) Old 07-07-2010, 02:25 PM
Main Motorcycle: '03 Sprint ST
pushr0d's Avatar
Other Motorcycle: 2000 Sprint ST (wrecked)
Extra Motorcycle: 1988 FXR Lowrider (sold)
Clegg,
Not familiar with the 1050 arrangement, but on the 955's, the hose routing kinda directs where the hoses go. Except the roll-over and scupper drain hoses, and one is in front of the other, so that's a no-brainer.
Still on a 955, if your bike has the same scupper drain setup, make sure the hose nipple is clear of mung when you take the hose off. A small drill bit, finger driven, is all it takes to clean it out.
Before you d/c the fuel fittings, put a shop rag underneath to keep the escaping drops from falling on the paint.
pushr0d is offline
post #8 of 19 (permalink) Old 05-23-2018, 03:34 PM
Main Motorcycle: 2002 Sprint RS
chickenstrip's Avatar
I'm picking up on this old thread as I'm having trouble avoiding gas leaking when I remove the tank. The fittings on the hoses are metal replacements and I think read a post by Decosse saying the metal fittings don't have shutoff valves. True?
How can I take the tank off without leakage (I'm talking continuous, not drops) and without draining the tank? By chance does it have to do with the order in which hoses are disconnected?
2002 Sprint RS: TOR silencer, LSL bars, Laminar lip, factory tail rack with Givi top box, custom painted OEM panniers (one of 'em anyway - sad story), M-Factory lowered pegs, Penske shock.Thanks for all the help, Kit!
chickenstrip is offline
post #9 of 19 (permalink) Old 05-23-2018, 05:26 PM
Main Motorcycle: 02 Sprint RS
Steve Ford's Avatar
Other Motorcycle: 06 Tiger
Extra Motorcycle: a few others
I don't have gas drooling away when I disconnect the lines.
If it's pressurized it'll give a blast but other than that, no real mess.
Steve Ford is offline
post #10 of 19 (permalink) Old 05-23-2018, 05:29 PM
Hmm, so what's up with my bike? Yours has the metal fittings, right?
I found the DEcosse post with mention of valved/non-valved fittings. I actually don't know what the valving refers to, but I'm thinking it may to do with auto shutoff.
BTW, thanks for the response, Steve. I've got the tank unbolted and waiting to hear feedback before proceeding or retreating.
Bonnie gas tank removal question mdr231 Air Cooled Twins Technical Talk 16 03-11-2007 10:46 AM
tank removal question Bert Air Cooled Twins Technical Talk 10 12-04-2006 08:10 AM
Tank sticker removal question? Wheeler Speed Triple Forum 7 05-31-2006 11:07 AM
tank removal / fitments question InParkSlope Speed Triple Forum 4 10-03-2005 09:50 PM
