Suspension query New Owner S3 R..2014MY - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 8 (permalink) Old 10-19-2019, 03:56 AM Thread Starter
Main Motorcycle: 2014 S3 R
Other Motorcycle: Honda CBR1000RR track
Extra Motorcycle: Govt supplied Bandit!
Hi all,
I'm back again Speedy no 3... (must stop selling good bikes! - 2009 model and 2011 model)
I've just purchased a 2014 S3 R.
But...
Its been lowered. It has an adjustable linkage at the rear and the forks have been dropped through the yokes.
Can someone pls take a pic of their std rear bottom linkage so I can compare. I’m guessing it’s only the ‘adjustable’ linkage on mine that needs changing or adjusting..?
Can anyone tell me std settings please. How much of the fork is above the top clamp?
and what is the ‘length’ of the std linkage- say hole centre to centre..? (what do i measure for the rear?)
I appreciate the front is an easy loosen, measure and refasten but what do i need to do to the rear. Should i replace the adjustable linkage or buy a new 'triumph std one. Anything that will have been altered..???
When i sold my 2011 S3 i gave away all my manuals etc... = dummy.
...and it only has 8k's but is a 2014 - should i get a proper dealer service (no dealer service except initial one!) and rear suspension bushes etc sorted (as per rumours of seizing etc)...??
any help greatly appreciated.
BTW when i went off track it was for a ST3RS (Too buzzy) then Monster 1200 (sh*t fuelling and handling despite spending a fortune) and KTM Superduke 1290 (bits kept dropping off!)
I love Trumpys!
ID:	659246   Click image for larger version
gsx97 is offline
post #2 of 8 (permalink) Old 10-20-2019, 01:43 PM
Main Motorcycle: 2013 Speed Triple R
jmardy's Avatar
Other Motorcycle: BMW Boxer Cup R1100S
Extra Motorcycle: '08 Aprilia Tuono Factory
Congrats!
I'm not a big fan of dealer servicing unless you have one you like and trust (I don't). If it were mine, I'd change the oil, flush the brake fluid and ride!
Re: the rear, I would try to revert it back to the stock dogbone and plates. I don't trust those things. That's just me though. While you're in there, clean and lube.
I measured my front triple clamp/fork. I can't guarantee this is stock as I'm the second owner and I know they've been out at least once for servicing. I don't know if the '13 and '14 have the same NIX30 forks so yours may not have the ring it the same place.
This is the right leg, measured at the 3 o'clock position if you were on bike looking down:
Dogbone:
jmardy is offline
post #3 of 8 (permalink) Old 10-20-2019, 04:50 PM
Speed 3 Pilot's Avatar
Other Motorcycle: 2010 Ducati Streetfighter
Originally Posted by jmardy View Post
Congrats!
What he said...valve adjustment isn't due until 12k miles, so change oil, flush brakes, and lube chain.
For aesthetics I swapped out the headlight bracket for a Street Triple 675 one...it lowers the headlights about one inch and makes them look more integrated with the bike and less like an afterthought....
You only live once...and I feel like I'm running out of time...
Speed 3 Pilot is offline
post #4 of 8 (permalink) Old 10-20-2019, 07:08 PM Thread Starter
Jmardy-
Many thanks for that ��.
I’ve just found a old post (5-8-2019) and their front measurement (S3R) taken between the line on the forks and bottom of the yoke is 5mm..yours is 7.38 - how does yours handle, what does it feel like?
I know suspension settings are ‘subjective’.
I’m just after the factory ‘std’ to start with...and i’m NOT vertically challenged... 6’3”
Deffo thinking about going back to original dogbone at the rear.. the adjustable doesn’t look strong enough -but hey..!
gsx97 is offline
post #5 of 8 (permalink) Old 10-20-2019, 07:43 PM Thread Starter
Speed...
IíVe looked but canít find a thread or pics about your headlight conversion..? Any pics before & after anywhere..?
gsx97 is offline
post #6 of 8 (permalink) Old 10-20-2019, 09:21 PM
jmardy's Avatar
Originally Posted by gsx97 View Post
Jmardy-
Iíve just found a old post (5-8-2019) and their front measurement (S3R) taken between the line on the forks and bottom of the yoke is 5mm..yours is 7.38 - how does yours handle, what does it feel like?
I know suspension settings are Ďsubjectiveí.
Iím just after the factory Ďstdí to start with...and iím NOT vertically challenged... 6í3Ē
Deffo thinking about going back to original dogbone at the rear.. the adjustable doesnít look strong enough -but hey..!
I can't remember if the TTX shock is length adjustable but you should check that too as someone who lowered it probably also shortened the shock.
Good to know about 5mm starting point.
Now that you mention it - and I don't know if this is because I'm switching between the Tuono, the BMW and the KTMs - but the Triple almost feels like it oversteers. I'll initiate a turn and feel like I need to reduce my input to get the line I want. Once in a turn it holds the line beautifully with no added input and it feels fantastic.
Enjoy!
jmardy is offline
post #7 of 8 (permalink) Old 10-21-2019, 03:27 PM
Lowered headlights mod...
https://www.thespeedtriple.com/forum...eadlights.html
https://www.flickr.com/photos/binsar...n/photostream/
Lots of reading, but the info is there...
post #8 of 8 (permalink) Old 11-04-2019, 04:46 AM Thread Starter
FYI..Speed R = 5MM gap as shown in official manual!
gsx97 is offline
