Speed triple R making sound after turning ignition on - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 10 (permalink) Old 09-08-2019, 04:20 PM Thread Starter
Hello everyone, my speed triple r is making a sound after turning ignition on. It also remains for few seconds after turning ignition completely off for. Check my video. Anyone know what’s that? How to fix it? Anyone got same problem ? Greeting someone https://m.youtube.com/watch?v=D9j_nV4Q2GY
Jakub95 is offline
post #2 of 10 (permalink) Old 09-08-2019, 07:59 PM
Main Motorcycle: 2004 Daytona 955i
Other Motorcycle: 2006 1050 Speed Triple
Extra Motorcycle: Vespa PX200
Stepper motor on ISC and fuel pump priming, perfectly normal.
Terry Colley is offline
post #3 of 10 (permalink) Old 09-09-2019, 01:01 AM Thread Starter
Are You sure there’s nothing to worry about ? I got this bike for two weeks and I didn’t noticed that earlier. First time I heard it was after washing(maybe I didn’t notice that sound but it was from beginning) it so I thought water get in and making trouble with electronics.
Jakub95 is offline
post #4 of 10 (permalink) Old 09-09-2019, 06:47 AM
Main Motorcycle: Sprint GT 2011 Blue
As the stepper is on the right side you should hear it louder on the right. The stepper self calibrates a few seconds after the engine is shut down. The noise may be different between 1050 years and models though.
The pump priming is occurring when the key is turned on and it's a different noise that last around 5 sec. If you stick your ear to the tanks you'll feel it better.
Fred
fredsprint is online now
post #5 of 10 (permalink) Old 09-09-2019, 07:34 AM Thread Starter
This noice last till I turn ignition off and even few seconds more. So what do u think everything is fine ?
Jakub95 is offline
post #6 of 10 (permalink) Old 09-09-2019, 07:37 AM Thread Starter
I don’t know if I uderstand you right, you say that this is not the voice of pump priming ? So what’s that? It requires repairing or something ?
Jakub95 is offline
post #7 of 10 (permalink) Old 09-09-2019, 09:02 AM
Main Motorcycle: Daytona 675R
Scottty's Avatar
Other Motorcycle: Thruxton R
That's definitely the throttle actuator motor as others have said, even though you're not twisting the throttle the motor is still active trying to maintain its position, if you open the throttle you'll hear the noise changing as the motor turns, my Thruxton makes exactly the same noise. Some may be louder than others depending on backlash in the system and so on.
Scottty is online now
post #8 of 10 (permalink) Old 09-09-2019, 09:20 AM Thread Starter
So should i leave it like that?
Jakub95 is offline
post #9 of 10 (permalink) Old 09-09-2019, 09:24 AM
Scottty's Avatar
Yes, if there was a problem with a throttle actuator or sensor you would have a malfunction light.
also it's probably not a good idea to leave the ignition on for any length of time without the engine running, I think it mentions it in the owner's manual.
post #10 of 10 (permalink) Old 09-10-2019, 02:28 AM
I didn't realize the last speed triples were ride by wire. If it's the case so it's pretty normal the stepper is actuating all the time.
Ride by wire since 2016 models as it appears.
Fred
