2006 S3 radiator size - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
  • 1 Post By Nicspeed
post #1 of 6 (permalink) Old 08-29-2019, 10:39 AM Thread Starter
Main Motorcycle: Speed Triple 2006
Nobby15's Avatar
Unhappy 2006 S3 radiator size
Hi all
Recently had a low side and damaged several parts of the bike, including the radiator which now needs replacing. Does anyone know whether i can use a rad from any other bike as there are very limited offerings on ebay.
Thanks in advance
Nobby15 is offline
post #2 of 6 (permalink) Old 08-29-2019, 12:44 PM
Main Motorcycle: 2016 Speed Triple R
Nicspeed's Avatar
You can use rads from ‘05-‘07 Speed Triples for sure.
And ‘08-‘10 but not 100% sure if those would be a straight fit.
Nicspeed is offline
post #3 of 6 (permalink) Old 08-29-2019, 01:01 PM Thread Starter
Nobby15's Avatar
Thanks Nicspeed, i just found that bikebandit has the same rad listed for 02 to 07 models. Think i'll have to go for the one on ebay as i need to get the bike running soon.
Nobby15 is offline
post #4 of 6 (permalink) Old 08-29-2019, 09:40 PM
Nicspeed's Avatar
I just checked BIkeBandit and they’re different part numbers, the ‘07 ends on 716 and the ‘02 ends on 802 and now I’m seeing that the ‘10 ends on 976 so it’s also different.
Differences are most likely bracket slight adjustments, you might be able to accommodate it with some minor surgery, will and ingenuity.
Nobby15 likes this.
Nicspeed is offline
post #5 of 6 (permalink) Old 09-04-2019, 11:17 AM Thread Starter
Nobby15's Avatar
Originally Posted by Nicspeed View Post
I just checked BIkeBandit and theyre different part numbers, the 07 ends on 716 and the 02 ends on 802 and now Im seeing that the 10 ends on 976 so its also different.
Thanks Nicspeed!
Nobby15 is offline
post #6 of 6 (permalink) Old 09-04-2019, 07:30 PM
Main Motorcycle: 2004 Daytona 955i
Other Motorcycle: 2006 1050 Speed Triple
Extra Motorcycle: Vespa PX200
You need a radiator from 2005 to 2010. 2011 they went to a curved core. The 955s prior to 2005 and all other variants will do the job but as Nicspeed says bracketry and indicator and oil cooler mounts all vary.
Terry Colley is online now
