Speed Triple 1050 supposedly burned all of it's oil - Triumph Forum: Triumph Rat Motorcycle Forums
 5Likes
post #1 of 34 (permalink) Old 08-25-2019, 08:08 AM Thread Starter
F4EPhantomII's Avatar
Yesterday I went riding with my group and one of my members has a 2016 Street Triple 1050 after we broke to head home I got a text saying his bike started making a loud banging noise and he was on the side of the road, when he took the bike to his mechanic he was told it was out of oil and that it must have burned all of the oil. My issue is when I was admiring his bike that morning I didn't notice any oil residue in or around his exhaust pipes so wouldn't there be a sign of burnt oil from a bike that had burnt over 4 qts of oil?
Best Regards
Devin
F4EPhantomII is offline
post #2 of 34 (permalink) Old 08-25-2019, 08:58 AM
Main Motorcycle: 2017 Speed Triple S
Speedy Russ's Avatar
Other Motorcycle: 2006 SV1000S
Extra Motorcycle: 2005 Crashed SV1000S
I had an '07 Speed Triple that lost about 1 quart of oil every 1,000 miles (which Triumph told me was normal). I had to really keep on top of checking the oil to keep it at recommended levels. But I would think his low oil warning light would have come on before he completely ran out, at least it should have.
You got loud pipes, but you ain't sayin' nothing!
Speedy Russ is online now
post #3 of 34 (permalink) Old 08-25-2019, 09:08 AM
Main Motorcycle: 2013 Speed Triple
Cburt's Avatar
It didn't burn 4 quarts of oil on one ride so why didn't he get a oil light way before damaging the motor? Sounds like gross neglect or stupidity.
Cburt is offline
post #4 of 34 (permalink) Old 08-25-2019, 10:38 AM
Main Motorcycle: 2007 Speed Triple
There may not have been obvious signs of the bike burning oil beyond the oil level getting lower. If he wasn't checking his oil regularly, this is how it happens.
Sent from my SM-N960U using Tapatalk
Night Train is offline
post #5 of 34 (permalink) Old 08-25-2019, 05:58 PM Thread Starter
I asked if his light came on he said the only thing he saw was the little wrench/maintenance indicator. Maybe his doesn't have an oil light i know nothing about the Speed triple i know my T120 has a light for low oil.
Best Regards
Devin
post #6 of 34 (permalink) Old 08-25-2019, 08:23 PM
Main Motorcycle: 2004 Daytona 955i
Other Motorcycle: 2006 1050 Speed Triple
Extra Motorcycle: Vespa PX200
There is no 'low oil warning light'. There is a an oil pressure light. This'll come on when there is no oil pressure. If this is caused by there being no oil then the damage will already be done.
Losing that much oil without anything amiss being noticed is really weird. Makes you wonder if the bike had been in for a service immediately beforehand and they didn't refill it after draining. Or did the drain plug come out? Or was the the oil filter loose? Burning that much oil? Unlikely methinks.
fredsprint likes this.
Terry Colley is offline
post #7 of 34 (permalink) Old 08-26-2019, 12:30 AM
Main Motorcycle: 2016 Speed Triple R
Nicspeed's Avatar
Not too unlikely, I should know. My departed ‘10 was guzzling an astronomical quart every 3 weeks. So yea...
Nicspeed is offline
post #8 of 34 (permalink) Old 08-26-2019, 08:03 PM
Main Motorcycle: Black 2010 Speed Triple
Other Motorcycle: Black '96 Speed triple
Extra Motorcycle: Black 2004 Speed Triple
On my 2009 speed triple I ran over something (a piece of steel rod I think) which flew up and punched a hole in my oil filter. The oil started to flow out and then the oil pressure light started to flicker then stayed on. I shut the motor down instantly and rolled to a stop. Oil kept running out onto the ground, but not too much. When I drained the remainder there was only about 250 mls left in the motor. I reckon I had lost at least 75% of the oil before the light came on. As i switched the motor off quickly I avoided any damage to the motor.
If your friend had shut down his motor as soon as the oil light came on he probably would be okay also, but if his motor is damaged, he probably ignored the light and kept riding.
John
I want to die peacefully in my sleep like my grandfather, not screaming
in terror like his passengers.
Legman is offline
post #9 of 34 (permalink) Old 08-28-2019, 04:14 PM
Main Motorcycle: Speed Triple R
Flyfisher's Avatar
My '12 Speed only used, maybe, a cup of oil between oil changes. I checked it before every ride.
Speed 3 Pilot likes this.
Flyfisher is online now
post #10 of 34 (permalink) Old 08-29-2019, 07:42 AM
Cburt's Avatar
That’s probably average. I’ve had 4 Speed Triples. Some didn’t use any and some did.
Current 2019 sips about like yours. Don’t check every time I ride but will before a trip and on returning.
Cburt is offline
