'05 speedy rear sub-frame crack - Triumph Forum: Triumph Rat Motorcycle Forums
 4Likes
  • 1 Post By DEcosse
  • 1 Post By DEcosse
  • 1 Post By DEcosse
  • 1 Post By Legman
post #1 of 8 (permalink) Old 08-12-2019, 09:59 AM Thread Starter
Main Motorcycle: Speed Triple 1050
surya's Avatar
Other Motorcycle: '98 Ducati M900
Unhappy '05 speedy rear sub-frame crack
Well it happened. After a few years and few thousand miles of amazing utility the Givi topcase #V46NT on the SW-Motech alu rack #GPT.11.259.15000.B with adapter plate #GPT.00.152.405 went over one too many Manhattan pothole and cracked the speedy's rear subframe just aft of the under seat tool space. Happened when I was riding with an empty topcase over Brooklyn bridge. Any tips for welding/strengthening the subframe or cautionary tales welcome.
ID:	652070   Click image for larger version
ID:	652072   Click image for larger version
'05 neon blue Speedy
surya is offline
post #2 of 8 (permalink) Old 08-12-2019, 06:23 PM
Supernova
DEcosse's Avatar
Expecially when loaded, that's a lot of load all leveraged off the weld, like a cantilever.
While welding, see if you can add some additional support off the round section tubing to web onto underside of the square section
surya likes this.
DEcosse is online now
post #3 of 8 (permalink) Old 08-13-2019, 11:39 AM Thread Starter
surya's Avatar
Thanks @DEcosse . Is the sub-frame part unchanged from 1994 T509 as this ebay listing says? Considering buying, drop shipping to welder to strengthen to save on transport costs.
surya is offline
post #4 of 8 (permalink) Old 08-13-2019, 12:20 PM
Supernova
DEcosse's Avatar
Well the part about 94-18 is complete rubbish - nothing before 05 or from 08 on will work and the 'one size fits that whole range' is absolute nonsense.
But looks like the correct one for your 05 from the pics and that is from an actual '07 bike
surya likes this.
post #5 of 8 (permalink) Old 08-14-2019, 09:25 AM Thread Starter
surya's Avatar
@DEcosse what are you looking for in identifying features on the sub-frame for '05-'08 compatibility? This listing is in better shape and cheaper but the vendor claims is from a 2008. The rear tank mount looks different but since we will be welding may be able to retrofit my current tank mount.
surya is offline
post #6 of 8 (permalink) Old 08-14-2019, 11:05 AM
Supernova
DEcosse's Avatar
Generally when the plastics change, the sub-frame changes - so the tank mount and possibly the tail plastics and seat mounts could be different
I think you're asking for more trouble to try to make the later one fit
surya likes this.
post #7 of 8 (permalink) Old 08-14-2019, 08:47 PM
Main Motorcycle: Black 2010 Speed Triple
Other Motorcycle: Black '96 Speed triple
Extra Motorcycle: Black 2004 Speed Triple
05-07 subframe is what you need. Decosse is right in that the 08-10 is different, and you would need all new bodywork, tail lights, coolant overflow reservoir and seat and the tank mount is different. 08-10 tank is metal.
The subframe mount is the same, from 02-10 and they are all interchangeable. I am currently fitting an 05 subframe and bodywork to my 04. The subframe bolted right up and the 05 rear body work matches up to the 04 tank, but the rest of the project is anything but simple. Work is suspended at the moment due to some other stuff I'm doing, but I have a thread going about the project which I'll update when work resumes. But I digress......if you want to replace the subframe, go for an 05-07 (I maybe wrong but I think I remeber Triumph upgraded the rear subframe bracing due to a few reports of similar failures on the 05-06 model) ....and dont use a loaded topbox on that rack. SW Motech changed the rack for the 08-10 models, and put some extra rails which mount to the rear of the rear footpeg mounts. they still advise a load limit of 5kg
surya likes this.
John
I want to die peacefully in my sleep like my grandfather, not screaming
in terror like his passengers.
Legman is offline
post #8 of 8 (permalink) Old 08-26-2019, 08:11 PM Thread Starter
surya's Avatar
Found a local welder and I'm going to reuse my sub-frame to try and make a beefier sub-frame leveraging the round section tubing as @DEcosse suggests above. Anybody have a process for removing sub-frame? Other than an exploded view of "seat rails" in 16.3 can't spot a remove/replace procedure in the factory manual. Some of the interior bolts have likely 14 years (!!) of corrosion on them and I'd like to see what needs to come off in what order to avoid hammering at things with a hidden bolt, or vice versa (see corrosion), and line up the right tools and grease in advance. Working on speedy in an NYC basement has its limits. Thanks in advance for any help.
surya is offline
