2019 S3 RS - Front right indicator fault - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 6 (permalink) Old 07-28-2019, 11:38 PM Thread Starter
Main Motorcycle: 2012 Triumph Speed Triple
syne7's Avatar
My new S3 immediately started out wth:
Front right Indicator Fault
Check manual
Got my bike on a Saturday and dealer is not open till tomorrow. Will be calling first thing in the morning.
Blinkers seem to work.
Anyone experience anything like this? I have not found anything searching the manual pdf file.
2019 Triumph Speed Triple RS
syne7 is offline
post #2 of 6 (permalink) Old 07-29-2019, 07:37 AM
Main Motorcycle: 2016 Speed Triple R
Nicspeed's Avatar
Welcome and congrats! It’ll probably clear out in a few heating cycles. It’s the electrical gremlins giving you the proper welcome. Yes, they are annoying, they are free, and we all triumph owners have to achieve special meditation skills to not set on fire our precious machines since the rising quality outweighs these critters.
Soaking that in... targeting this new-to-me gremlin...
Did you have the dealer swap the signals for the LED ones? Or maybe they weren’t working and they just replaced it? (They probably didn’t mention it if that’s the case) If so, when installing the signal they could've turn the key on at some point and the ECU detected a missing turn signal or touching cables (shorting) that might’ve triggered the code and will self cancel after it keeps confirming there’s no shorting or open terminals.
Nicspeed is online now
post #3 of 6 (permalink) Old 07-29-2019, 10:21 AM Thread Starter
syne7's Avatar
Thank you very much. I appreciate the insight. I will check the signals.
syne7 is offline
post #4 of 6 (permalink) Old 07-29-2019, 10:28 AM
Nicspeed's Avatar
Well, you say they’re working fine, so you don’t really have to check anything. Like I said the ECU will clear the fault in a few heating cycles if there’s no problems with it.
post #5 of 6 (permalink) Old 07-29-2019, 01:54 PM Thread Starter
syne7's Avatar
Sorry, I meant check to see if they've been replaced with LEDs.
syne7 is offline
post #6 of 6 (permalink) Old 07-29-2019, 01:56 PM Thread Starter
syne7's Avatar
Whoever assembled the bike did not set up the date & time etc... which caused an alert when I set them. Not sure it was looked over with a detailed eye .
syne7 is offline
