Leaking Gas Tank - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 7 (permalink) Old 07-09-2019, 01:05 PM Thread Starter
Leaking Gas Tank
So some idiot in a 4runner backed into my bike and decided to run. Thanks to the witness for coming into my work office at the time to inform me (wish he grabbed the plates).
With that being said, I have fixed all the cosmetics that were damaged but now I see that shes leaking gas. The tank is leaking from the sides of the rear mounting plate shown in the picture.
Any suggestions as to what you guys think would be the best option for repair?
haharel is offline
post #2 of 7 (permalink) Old 07-12-2019, 12:27 AM
SussSpeed3's Avatar
This is exactly what happened to mine when it got reversed into.
You need to seal the inside of the tank. I used KBS gold standard tank sealer kit. It comes with 3 components. A cleaner, an etcher and a sealer. It will plug up any leaks you have and will treat your tank from any rust or corrosion and protect it for 10 more years. Be careful though, the sealant is bulletproof and will latch on to anything it comes into contact with.
SussSpeed3 is offline
post #3 of 7 (permalink) Old 07-12-2019, 01:12 PM
Main Motorcycle: 2000 Triumph 955i S3
Rayvin's Avatar
Originally Posted by haharel View Post
S.
I've used Caswell tank sealer expoxy (thanks to recommendation from DeCosse) successfully on the tank of my 2000 S3 955i. It's the nylon compound tank, but it's supposed to work well on the metal ones as well. Well worth the 45 bucks for the kit. Get the larger kit if you do, as I used the whole large kit to coat my tank and it needed it. A lot of surface area, at least in my particular tank.
Rayvin is offline
post #4 of 7 (permalink) Old 07-12-2019, 09:44 PM
Main Motorcycle: 2004 Daytona 955i
Other Motorcycle: 2006 1050 Speed Triple
Extra Motorcycle: Vespa PX200
I'm surprised the tank is leaking there. The support bracket is (presumably) spot welded to the tank itself so it must have taken quite a hit to 'tear' one of the spot welds but the tank doesn't seem to exhibit any damage. What a bummer. Nice red/white paint job too - same as mine but mine is one of the last plastic (nylon) tank models.
Terry Colley is offline
post #5 of 7 (permalink) Old 07-12-2019, 10:12 PM
SussSpeed3's Avatar
If the tank was full of petrol and the bike fell on its side, that would be enough weight to put that sort of stress on the pinch weld. Same thing happenend to mine.
post #6 of 7 (permalink) Old 07-13-2019, 01:24 PM Thread Starter
Thanks for all the responses. I just received my KBS tank sealer.
Do you guys have any tips for applying this stuff? So far I’ve read that covering the fuel pump with a nice durable plastic bag and then mounting it back in would be ideal.
Also, what about the vent and breather lines/holes. I haven’t really taken a good look at my tank, and I wonder if the epoxy will creep into those vents when applying. Thoughts?
haharel is offline
post #7 of 7 (permalink) Old 07-14-2019, 02:29 AM
SussSpeed3's Avatar
I took the pump , float gauge and the filler cap completely out and used a fuel pump blanking plate (basicly a thin bit of ply and a thin sheet of rubber glued to it with holes drilled in it to match the fuel pump screw holes) to block the fuel pump hole and I found a sink plug to fit into the filler hole. Then i just poured the sealant in and rolled it all around the tank. On my tank none of the actual breather/overflow lines actually are exposed from inside the tank, I think they are only accessible via the filler neck which the sealant can't actually get to.
Have a look and let me know. Are you in Sydney? You can come and pick up the blanking plate and plug if you want.
