2019 Headlight Disconnect for Track Day - Triumph Forum: Triumph Rat Motorcycle Forums
 3Likes
post #1 of 12 (permalink) Old 06-23-2019, 01:18 PM Thread Starter
Main Motorcycle: Speed Triple RS
AirAntix's Avatar
I saw a post from 2010, but has anyone messed with a 2019 Speed Triple to see if there is a simple fuse or plug to kill the lights to prevent overheating while they are taped up?
AirAntix is offline
post #2 of 12 (permalink) Old 06-23-2019, 08:42 PM
Main Motorcycle: 2017 Speed Triple
jer5ak's Avatar
Other Motorcycle: 1985 Suzuki 1150
Extra Motorcycle: 2002 Triumph ST
A lot of systems run through the light harness. The European light switch has an off/on setup. If doing a lot of track days I would go with that. I know my 17 has the weird headlight series wiring.
When all else fails, get a bigger hammer!
jer5ak is offline
post #3 of 12 (permalink) Old 06-23-2019, 09:06 PM
Main Motorcycle: 2004 Daytona 955i
Other Motorcycle: 2006 1050 Speed Triple
Extra Motorcycle: Vespa PX200
If you have an example I'd like to see it.
Only switch blocks I've ever seen with on/off switches were on certain 955s from 1997 -2006. Never seen anything later than that (apart from my own bike that I retrofitted).
Terry Colley is offline
post #4 of 12 (permalink) Old 06-24-2019, 07:52 AM
Main Motorcycle: 2013 Street triple r
Gzblack2's Avatar
Other Motorcycle: 2006 ninja 250
Extra Motorcycle: 2004 honda vtx
The beginning of this shows how to remove the flyscreen to get to the headlight plug.
Sent from my iPhone using Tapatalk
Gzblack2 is offline
post #5 of 12 (permalink) Old 06-24-2019, 07:54 AM
Gzblack2's Avatar
https://youtu.be/gvHtPlvxTQM
I realize itís for a street triple,but Iím guessing itís similar if not exactly the same.
Gzblack2 is offline
post #6 of 12 (permalink) Old 06-24-2019, 09:15 PM Thread Starter
AirAntix's Avatar
Sweet...I’ll check it out! Thanks.
AirAntix is offline
post #7 of 12 (permalink) Old 06-25-2019, 02:27 AM
Not sure about the current 2019 RBW models but if it's anything like the earlier 1050s interrupting the headlight supply means you'll probably have to put a jumper across the starter lock out circuit on the cluster/ECU canbus.
post #8 of 12 (permalink) Old 06-25-2019, 04:01 PM
Main Motorcycle: 2017 Speed Triple R
Other Motorcycle: 2015 Honda Grom
I have a 2017 Speed Triple. For track days, I just disconnect the plug off the bulb (leaving it in the headlight assembly), and put the dust cover back on. It is super easy and prevents the headlight from being on and thus overheating with lights taped up.
xorbe and AirAntix like this.
chrisok1 is offline
post #9 of 12 (permalink) Old 06-25-2019, 08:55 PM
Good idea. Simple and does the job.
post #10 of 12 (permalink) Old 06-29-2019, 10:31 PM Thread Starter
AirAntix's Avatar
Worked perfectly...was quick and easy. Appreciate the tip. Only took about 2 minutes.
AirAntix is offline
