'16 Speed Triple Front Brake Issue (Brembo) - Triumph Forum: Triumph Rat Motorcycle Forums
 16Likes
post #1 of 121 (permalink) Old 05-22-2019, 09:17 PM Thread Starter
Main Motorcycle: 2016 Speed Triple
nugpop's Avatar
Other Motorcycle: 1968 Triumph Bonneville
Hello all, my Speed Triple has developed a condition where the front brake must be pumped once for a solid response. To be clear, there is a 1/2 inch (or more) difference between the first pull of the brake and a second pump. Further, it doesn't stay pumped... every time I apply the brakes, I have to do a double pump. Really frustrating, as the system has been bled countless times to no avail, master cylinder replaced under warranty (no difference) and most recently ABS pump replacement (no difference). Any ideas as to what else would cause this to happen?
nugpop is offline
post #2 of 121 (permalink) Old 05-22-2019, 09:48 PM
Main Motorcycle: 2016 Speed Triple R
Nicspeed's Avatar
I have a ‘16 as well and I’ve noticed that double pump difference actually today.
I’ve been overseas for 9 days and upon return I picked up the bike at the airport’s lot, the lever went down almost touching the grip, second pump was almost normal, maybe half way and third one was normal.
This tells me that this may be normal operation if it’s happening to other bikes, especially with the indirect ABS box. As per my mechanic, brakes with ABS will feel not as sharp but more “progressive” as you squeeze.
I remember my 2010’s brakes were way more responsive than these fancy-pants system. I guess it’s all about having ABS nowadays.
I just ordered a racing-grade brembo fluid with hardness higher than 5.1 fluids and brembo brake pads also racing grade which operate at cold temps too. I still have some of the old pads left to wear so I’ll report when I replace those parts.
There’s not really much more you can do since you bled the system assuming that the fluid you’ve used was from a new, sealed bottle that’s is.
nugpop likes this.
Nicspeed is online now
post #3 of 121 (permalink) Old 05-22-2019, 09:56 PM Thread Starter
nugpop's Avatar
Thanks for the comparison. Check out a new speed triple in the showroom. I've tried several and none do this. All work was done under warranty by a factory mechanic. They are stumped, as are the techs at Triumph. I'd think that if this is a development, rather than an existing-from-new issue, something is off. I ride in the city every day and the double-pump thing is getting a bit old. Yeah man, please let me know what results you get, will follow the thread.
nugpop is offline
post #4 of 121 (permalink) Old 05-22-2019, 09:58 PM Thread Starter
nugpop's Avatar
And yeah...I trade my 08 for this one. Way more responsive. ****, I miss that bike!
nugpop is offline
post #5 of 121 (permalink) Old 05-23-2019, 06:19 PM Thread Starter
nugpop's Avatar
Has anyone else experienced this on their 16+ Speed?
nugpop is offline
post #6 of 121 (permalink) Old 05-25-2019, 07:06 AM
Main Motorcycle: 2017 Speed Triple S
Speedy Russ's Avatar
Other Motorcycle: 2006 SV1000S
Extra Motorcycle: 2005 Crashed SV1000S
Yup! Now that I've gotten some proper seat time on my '17 S3, there is definitely a lot more "play" in the front brake lever vs my previous S3's. I'm with Nicspeed as to the reason why; ABS. On mine, it seems the brake lever firms up nicely the harder you brake. These are really great brakes too.
You got loud pipes, but you ain't sayin' nothing!
Speedy Russ is online now
post #7 of 121 (permalink) Old 05-25-2019, 07:59 AM
Main Motorcycle: 2013 Speed Triple
Cburt's Avatar
Traded my 16 for a 19 recently. The issues you have are the same as my 16.
I had Pazzo levers and on low setting could pull them to the hand grip.
Made several claims to dealer who didn’t do anything to resolve.
It actually improved a little on its own after 15,000 miles????
Last resort was to purchase Brembo pads but never got around to install before trading for the 19S version.
Still have the pads if anyone is interested.
nugpop likes this.
Cburt is online now
post #8 of 121 (permalink) Old 05-25-2019, 09:08 AM
Nicspeed's Avatar
Damm and I JUST got a set that arrived yesterday. Did you post them in classifieds? I would’ve taken them given they are suitable for street and not just racing.
post #9 of 121 (permalink) Old 05-25-2019, 09:34 AM
jokingjimmy's Avatar
I'm new to motorcycles maintenance but the first thing that comes to mind in a car is improper bleeding (which still might be the case - mechanics are notorious for being wrong). For example my mechanic bled my system on my car three times before I had him switch which brake was bled first, aND bingo! Problem solved. I know it was a car, but still same concept.
Second is I'd guess there is water in the line. Maybe the cap in the reservoir was improperly sealed and allowed moisture in.
Next I'd say the master cylinder is going bad, one of the internal pressure plates or whatever. Also maybe a bad piston in the calipers.
Just my guess here lol.
FYI my '19 S has no soft brake issue like your describing.
nugpop likes this.
jokingjimmy is offline
post #10 of 121 (permalink) Old 05-28-2019, 10:25 AM Thread Starter
nugpop's Avatar
Made several claims to dealer who didnt do anything to resolve.
Thanks. Same here. Pazzos touch the grip at low setting. There is no way this is ok. Still under warranty, so hoping it can be somehow sorted. Really not cool having to double-pump every time I brake.
So far, the lines have been bled multiple times (by dealer), new master cylinder and new ABS pump. No improvement. Back to the drawing board and def not comfortable with accepting this as a "characteristic" of a $13K machine.
nugpop is offline
Alternatives to T140 brake master cylinders? [email protected] Classic, Vintage & Veteran 74 09-05-2019 10:22 AM
2015 speed triple intermittent hot staring issue and warranty brotherbanzai Speed Triple Forum 21 02-13-2017 01:31 PM
Persistent Battery Drain Issue Speed Triple arodnyc Speed Triple Forum 14 01-08-2013 11:40 AM
675 Piston Swap Procedure - LONG!! david_m Sprint Forum 111 06-03-2012 01:07 AM
Suspension Setup - Step by Step Sparti Speed Triple Forum 11 05-28-2006 02:33 AM
