'16 Speed Triple Front Brake Issue (Brembo) - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
 5Likes
post #11 of 43 (permalink) Old 05-28-2019, 12:49 PM
Main Motorcycle: 2004 Speed Triple 955i
That sounds a lot like the symptoms of having air in the system somewhere. Might not be. If it is, the problem can be that it is hard to bleed ABS systems properly. Bleeding at the junctions can help - I have a friend who had this issue on a Thruxton and resolved it that way. for what it's worth...
nugpop likes this.
Billy10 is offline
post #12 of 43 (permalink) Old 06-05-2019, 11:54 AM
Main Motorcycle: 2017 Speed Triple S
Speedy Russ's Avatar
Other Motorcycle: 2006 SV1000S
Extra Motorcycle: 2005 Crashed SV1000S
Originally Posted by nugpop View Post
....Pazzos touch the grip at low setting....
Just curious, did you have the same issue with the stock lever?
You got loud pipes, but you ain't sayin' nothing!
Speedy Russ is online now
post #13 of 43 (permalink) Old 06-05-2019, 12:52 PM Thread Starter
Main Motorcycle: 2016 Speed Triple
nugpop's Avatar
Other Motorcycle: 1968 Triumph Bonneville
Pazzos went on during first week of ownership.
nugpop is offline
post #14 of 43 (permalink) Old 06-05-2019, 12:53 PM Thread Starter
nugpop's Avatar
Bringing it back in to the dealer for yet another round of service. Will update when/if this is resolved.
nugpop is offline
post #15 of 43 (permalink) Old 06-05-2019, 02:19 PM
It might be worth putting the stockers back on to see if your issue improves. Like I said earlier, my lever compresses some before I have full braking power. But I still have plenty of room between the lever and bar when it does happen. The Pazzos are likely magnifying this effect IMHO.
post #16 of 43 (permalink) Old 06-05-2019, 04:13 PM
Main Motorcycle: 2013 Speed Triple
Cburt's Avatar
Did in my case.
Cburt is online now
post #17 of 43 (permalink) Old 06-05-2019, 04:28 PM
Main Motorcycle: 02 Sprint RS
Steve Ford's Avatar
Other Motorcycle: 06 Tiger
Extra Motorcycle: a few others
If you want to work on it yourself, try this on a dry day:
Get some brake cleaner and some Permatex Brake Piston Lubricant from your local auto parts store, loosen the pad securing pin, remove the pads and remove the left hand caliper.
Loosely reinstall the pads and pump the pads shut against a clean screw driver.
Cover all body work with an old towel and remove the master cylinder cover.
Hit the pistons with brake cleaner and a paper towel and put the piston lube on the pistons with a Q-tip or similar.
Gently lever the pads back, pump the pads shut, repeat a few time, reinstall caliper.
Clean the pad securing pin and give it a light coat of anti seize, install pads, torque caliper mounting bolts.
Do the same thing to the right hand caliper.
Pump brake firm, check fluid level, reinstall master cylinder cap.
With any luck, that should do the trick.
Steve Ford is offline
post #18 of 43 (permalink) Old 06-05-2019, 05:30 PM
If there is air in the system then you need to get it out. ABS systems have control units that sit between m/c and calipers and they tend to have various unions which mean air will not easily travel all the way from caliper to m/c. For a start, if you work on the calipers, bleed them afterwars as the bleed nipples tend to be the highest point of the caliper - there is no point in working the pistons back and forth to shift air if it collects at the bleed nipple but doesn't get bled. You can bleed every union like a caliper by applying slight pressure at lever, cracking the relevant banjo or union, and doing up again as small amount of fluid seeps out. Makes sense to bleed m/c this way as well (some m/cs have a bleed nipple for that purpose, but my S3 doesn't so I just use the banjo to bleed it). If you are methodical in that way then you have a decent chance of removing most air from system. On my ABS bike (not a Triumph) I don't need to bleed all the unions but I do bleed m/c; on my S3 I displace the left side caliper and drop it below right side caliper to take brake line over mudguard out of equation as air can sit at the top of the brake hose. And as i mentioned i have a friend whose problem was only fixed by dealer bleeding the abs unit too. If you have eliminated the possibility of air in the system, then look at other issues. But you should be able to get something passable
Billy10 is offline
post #19 of 43 (permalink) Old 06-07-2019, 12:04 AM Thread Starter
nugpop's Avatar
Brand new ABS pump installed by Triumph mechanic. System was bled multiple times at the direction of Triumph before warranty work would be approved.
nugpop is offline
post #20 of 43 (permalink) Old 06-07-2019, 02:56 AM
Supernova
DEcosse's Avatar
@Steve Ford thinking in line with my thoughts - I think there is stiction of the seals on the pistons in the calipers - the seals are pulling the pistons back again, leaving a large gap between the pads and the rotor, hence the double pump to get it to close and work. Then they get retracted again by the elastic nature of the seals, after the pressure is off. Normally they should be 'self-adjusting' effectively only retracting so pad is only marginally off the rotor (almost touching but not applying any braking force).
You recognize this effect when you install new pads - you push back the pistons to create the space required for the new thicker pads; then, even with bleeding, when you pull the lever initially it will not yield any resistance and you need to 'pump' the lever several times and then it will be rock hard all of a sudden - this is because there is not resistance as the pistons/pads are moving only very small distance and require multiple pumps until that gap is closed up; of course then it should stay there. So the double pump is kinda doing the same thing, it needs to move the pad initially and then again with the second pump. You are talking very small distance here, compared to the lever travel.
You might actually find new pads would at least temporarily 'fix' it, as the pistons would have to be pressed back into a different position within the caliper cylinder than the current pad thickness allows. But it will likely return again.
If still under warranty I would request new set of calipers and of course yet another bleed would be necessary. I hate to disagree with Steve since we are essentially on the same page, but whether you or the shop does the work, the calipers need to be stripped and cleaned and new seals (& maybe even pistons replaced). But under warranty I'd be insisting on replacement calipers.
Incidentally Speed Triples underwent a very similar problem with the 05-06 S3's with Nissin calipers - Triumph did not do a full recall but offered a 'goodwill' replacement of the pistons with those from the Daytona 675, for anyone who asked.
DEcosse is online now
Alternatives to T140 brake master cylinders? [email protected] Classic, Vintage & Veteran 54 08-27-2018 09:18 AM
2015 speed triple intermittent hot staring issue and warranty brotherbanzai Speed Triple Forum 21 02-13-2017 01:31 PM
Persistent Battery Drain Issue Speed Triple arodnyc Speed Triple Forum 14 01-08-2013 11:40 AM
675 Piston Swap Procedure - LONG!! david_m Sprint Forum 111 06-03-2012 01:07 AM
Suspension Setup - Step by Step Sparti Speed Triple Forum 11 05-28-2006 02:33 AM
