2005 Ran out of fuel, won't restart - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 16 (permalink) Old 05-20-2019, 09:21 AM Thread Starter
Just picked up a 2005 Speed Triple 1050 that has a bit of an issue. Previous owner ran it out of fuel on the road, then when they put fuel back in it, it would not start. Any ideas were to begin on diagnosis?
Part of me thinks it might have just hurt the fuel pump.
Thanks in advance,
Henry
HenryW33 is offline
post #2 of 16 (permalink) Old 05-20-2019, 09:42 AM
Main Motorcycle: 2017 Speed Triple S
Speedy Russ's Avatar
Other Motorcycle: 2006 SV1000S
Extra Motorcycle: 2005 Crashed SV1000S
Interesting. Maybe some crud lurking at the bottom of the tank got pulled in? You may have to pull the pump out and inspect the screen. I'd check the fuse for the fuel pump too, especially if you don't hear it prime when you turn on the ignition. Let us know what you find out.
You got loud pipes, but you ain't sayin' nothing!
Speedy Russ is online now
post #3 of 16 (permalink) Old 05-20-2019, 10:36 AM Thread Starter
Any idea what years/other bikes are compatible fuel pump wise? Grand scheme of things for what I paid for the bike plus even a brand new fuel pump I am still going to end up ahead on this thing as an alternative to the Ducs in the garage.
HenryW33 is offline
post #4 of 16 (permalink) Old 05-20-2019, 10:56 AM
Supernova
DEcosse's Avatar
What happens when you turn on the key (before attempting to start) - can you hear the pump whine for about 3 secs (the priming step)?
It should do that every time you turn it off/on again - or just setting the Kill/Run to Kill, then Run again.
You can check for 12V across the pump connector but remember it will be only be there for 3 seconds when you first turn it on
i.e. set probes across connector, turn ignition on (operating the Kill/Run is easier) and get 12V for 3 secs, then will go to zero - turn off/on and check again.
If you do NOT get 12V, then check
a) Fuse #4
b) The Fuel Pump Relay (swap it with the Cooling Fan Relay)
Other status questions:
Are Neutral and Oil Lights on when you turn on ignition?
Cranks OK, just does not start?
DEcosse is offline
post #5 of 16 (permalink) Old 06-06-2019, 04:10 PM Thread Starter
Pump is good to go now. Spark is good on all three coils/plugs. Fuel injectors are not firing upon starting.
Need to get some paper clips because my multimeter probes aren’t small enough to get to the metal parts on the connectors for the injector harness. Thoughts? The gas I drained out of the tank was NASTY to the 10th degree.
HenryW33 is offline
post #6 of 16 (permalink) Old 06-07-2019, 01:51 PM
Have you checked the fuel filter?
Swoosh is offline
post #7 of 16 (permalink) Old 06-07-2019, 11:56 PM
WhyOWhy's Avatar
I’m having starting problems too, possibly fuel system related. I have a post going on about it looking for illumination.
I’m curious if you could get your bike started and add an additive to your gas like seafoam, it could maybe clear your injectors assuming they work and are just gummed up. I get my bike to start by spraying a little starter fluid in the air box.
WhyOWhy is offline
post #8 of 16 (permalink) Old 06-08-2019, 02:06 AM
jer5ak's Avatar
Other Motorcycle: 1985 Suzuki 1150
Extra Motorcycle: 2002 Triumph ST
If the spray starts it , itís a fuel delivery issue. Start simple : filter, fuse, pump and clean tank. Check fuel rail for blockages. Nasty gas clogs everything. I just went through that when I picked up a 02 st that had been sitting awhile. Check for vacuum leaks at the throttle bodies and not plugged or cracked. I changed everything rubber and fuel fittings. It fired right up clean. It also had a pc3 which I took off since it ran like crap with it on. Under $100 for everything and about 3-4 hours of work. These bikes are so easy to work on , even a caveman can do it.
When all else fails, get a bigger hammer!
jer5ak is offline
post #9 of 16 (permalink) Old 06-08-2019, 06:36 AM Thread Starter
Starter fluid did not start the bike unfortunately. Even sprayed while cranking
HenryW33 is offline
post #10 of 16 (permalink) Old 06-08-2019, 08:37 AM Thread Starter
Is there a pic of how all the vacuum lines go? Some are missing and some are shredded 😕
HenryW33 is offline
2012 street triple fuel pump problem and resolution RedwoodMan Street Triple Forum 3 06-08-2013 03:13 PM
2005 Fuel Sending unit TRI-AL The Rocket Science Forum 3 06-08-2013 10:30 AM
Ahem...this is a bit embarassing gripperod T3 Sport / Touring Forum 19 03-06-2012 09:53 AM
Ran Out of Fuel bonza Air Cooled Twins Technical Talk 23 05-28-2011 06:40 PM
Triumph Sprint ST 2005 fuel leak BikerBore Sprint Forum 9 03-02-2006 01:21 PM
