T509 violent misfire high revs - Triumph Forum: Triumph Rat Motorcycle Forums
 2Likes
  • 1 Post By DEcosse
  • 1 Post By Hubba94
post #1 of 10 (permalink) Old 05-13-2019, 04:02 PM Thread Starter
Newbie
Hi all,
I've got a nasty misfire past half throttle at around 6-9k rpm in any gear. It's like riding a bucking bronco!!! Started after yesterday with the mrs on the back and has carried on all day today so it's not bad fuel as I've drained it and filled with super...
I've stripped it down tonight, tank off and air box off but cant find anything untoward? Pipes all fine, connectors tight...
Anyone have any ideas what it might be?
Cheers, Hubba
Hubba94 is offline
post #2 of 10 (permalink) Old 05-13-2019, 05:07 PM
Main Motorcycle: 2017 Speed Triple S
Speedy Russ's Avatar
Other Motorcycle: 2006 SV1000S
Extra Motorcycle: 2005 Crashed SV1000S
How do your plugs look? I had some pretty bad misfiring on my '06 SV1000S despite new plugs, stripping the tank of some rust, and replacing a corroded fuel pump. Damn near threw me off the bike a couple of times too. It didn't clear up until I inspected my spark plug wires. That was the issue. When the bike got hot, the rubber insulator sheath expanded just enough to cause the front cylinder to misfire at high RPMs. The rubber insulation even got blasted by sparks as you can see in the top right pic. After snipping a few mm from each plug wire (the part that shoves into the coil), the problem was solved.
You got loud pipes, but you ain't sayin' nothing!
Speedy Russ is online now
post #3 of 10 (permalink) Old 05-16-2019, 05:08 AM
Main Motorcycle: Sprint GT 2011 Blue
The spark current doesn't go into any wire on triumph bikes. Only primary is wired. It's coil over plug.
Given what you show I tend to think the SV has a central coil so spark current (high voltage) is flowing through the wires.
DEcosse to confirm that.
Fred
fredsprint is online now
post #4 of 10 (permalink) Old 05-16-2019, 04:04 PM
Fred
Not sure about the specific differences between the SV's coils vs the T509's. Below is a pic of them with the SV's on the left. I circled the places where the wires can be twisted out of the SV's coils, clipped, and then replaced. The T509's coils are on the right. They look quite similar to me.
post #5 of 10 (permalink) Old 05-16-2019, 04:23 PM
Supernova
DEcosse's Avatar
Those are NOT Triumph coils - indeed they can't even be coils since they have HT leads on them
The Triumph stick coils go directly onto the plugs and there is only the Low Voltage wires on a connector that plugs directly into them
These are Gen 1 Coils
Later ones are similar, different connector
I would say the symptom is very much like a coil breaking down ............
DEcosse is online now
post #6 of 10 (permalink) Old 05-16-2019, 04:25 PM
My apologies. I pulled that pic from this eBay ad: https://www.ebay.com/itm/Triumph-Spr....c100005.m1851
post #7 of 10 (permalink) Old 05-16-2019, 04:34 PM
Supernova
DEcosse's Avatar
^ Those are from a T3 (carburetor generation) bike and indeed are just HT cables - no coil; the coils are discrete, remotely mounted.
post #8 of 10 (permalink) Old 05-16-2019, 05:05 PM
Thank you for the clarification DEcosse. I have to admit my ignorance about Triumph's as I've never even changed spark plugs on any that I've owned.
I take it that the wires/cables cannot be removed from any part of the T509's assembly as they can in the SV/s? So apparently, you'd need to check for voltage with a multi meter and replace the entire assembly if bad?
post #9 of 10 (permalink) Old 05-16-2019, 06:05 PM
Supernova
DEcosse's Avatar
There are no HT cables at all - the High Voltage output of the coil 'stick' goes directly onto the plug cap.
You can sometimes see a difference in the resistance of the low voltage connection - however with a high rpm breakdown, this is going to be difficult to identify
TuneECU would likely report an error however and point the appropriate coil/plug as to which is the issue
@Hubba94 - was your MIL (check engine light) on when this happened?
Speedy Russ likes this.
post #10 of 10 (permalink) Old 05-17-2019, 01:23 AM Thread Starter
Newbie
I persevered with it and it finally threw a code yesterday! TPS input low... the connector has been broken and doesnt quite stay on the TPS!
So I've managed to wedge it on for now with the air box pipe and all is now well.
Cheers for the input all!
Hubba94 is offline
rev's too high, jets to big?? technogrunt Air Cooled Twins Technical Talk 10 03-28-2007 11:29 PM
Need some help guys....stalling after high rev's Iggy762 Sprint Forum 11 10-12-2006 10:13 AM
5000 rpm Is this not High revs for cruising speeds? sredmon1 Tiger Workshop (archive) 11 06-29-2006 04:14 PM
Lean at high revs? JWoodsie Hinckley Classic Triples 3 08-15-2005 02:49 AM
Trouble starting, misfire at high rpm's 97Daytona Daytona Deliberations 1 07-06-2005 10:31 AM
