Rusty screw/nut - Triumph Forum: Triumph Rat Motorcycle Forums
 2Likes
post #1 of 13 (permalink) Old 05-13-2019, 02:27 PM Thread Starter
Main Motorcycle: Speed Triple
H_S3's Avatar
Rusty screw/nut
Hi all! Any of you guys know if I can easily change the rusty screw and nut in the picture? Left side of the bike. Haven't tried to unscrew it yet. Thnx!
H_S3 is offline
post #2 of 13 (permalink) Old 05-13-2019, 02:55 PM
Supernova
DEcosse's Avatar
Nut should come off - give a good soak overnight in penetrating oil first
Stud is a 50/50 - you might be just as likely to break it and then you have a MUCH bigger job on your hands - I would leave that alone unless you REALLY need to remove
DEcosse is online now
post #3 of 13 (permalink) Old 05-13-2019, 03:26 PM Thread Starter
H_S3's Avatar
Thnx for the answer! I will replace the nut.
Why is the stud more difficult?
H_S3 is offline
post #4 of 13 (permalink) Old 05-14-2019, 02:45 AM
Supernova
DEcosse's Avatar
It's a steel stud in aluminum head
post #5 of 13 (permalink) Old 05-14-2019, 11:40 AM
Main Motorcycle: 05 Speed Triple
Al'Speed3X's Avatar
it should come off as Decosse mentioned with the penetrating oil ... however there is 5 more of those nuts most likely in the same or worst condition. i would think the reason you want to replace is because it looks like dog crap. however the one you showed its probably the easiest one to remove and reinstall ... for the rest of them you will need to move the radiator a bit to get a good grip on the rest of them. (2) per exhaust ports x 3. my recommendation is to tackle this job when time comes around to do other maintenance. if you get lucky enough and the studs are in good condition and stay in place you will most likely not need to move the header and new copper gaskets will not be necessary, however if you need to move the header out of place you will need (3) copper gaskets just to make sure the exhaust system wont leak at the mating surface. believe me you don't want to install everything fill your radiator and find out you now have a leak. f*&K. if you are due for a coolant change, it be the perfect timing for this job.
Ride-on
Al'Speed3X is offline
post #6 of 13 (permalink) Old 05-14-2019, 04:38 PM
Mashers's Avatar
I would recommend using heat... Mine were in much worse condition but I got the studs out and replaced them after soaking them and using a blowtorch.
Much easier if you drain and remove the radiator... You should definitely check the others don't look like this...
https://www.triumphrat.net/biker-hang-out/945692-check-out-my-nuts.html
Mashers is offline
post #7 of 13 (permalink) Old 05-15-2019, 05:05 AM Thread Starter
H_S3's Avatar
All, thank you for the detailed answers. Indeed something to do at the end of the season (was planning to replace the coolant anyway). In the meantime I've fund a number of other threads indicating the same problem. Do you know if there is a stainless steel replacement such that this does not happen again?
edit;
Something like this seems to be a good option; https://www.ebay.ie/itm/Triumph-Exha...item1ccfb19a79
H_S3 is offline
post #8 of 13 (permalink) Old 05-15-2019, 08:14 AM
Main Motorcycle: 2004 Speed Triple 955i
Billy10 is offline
post #9 of 13 (permalink) Old 05-18-2019, 08:16 AM
Couldnt' find this before, but have now. Mashers spot on. Worth a look for the explanation
Billy10 is offline
post #10 of 13 (permalink) Old 05-20-2019, 09:20 PM
Main Motorcycle: Black 2010 Speed Triple
Other Motorcycle: Black '96 Speed triple
Extra Motorcycle: Black 2004 Speed Triple
If you do decide to replace the nut only, use anti seize on the stud before you screw the new nut on. This will help you achieve the required torque and make it easier to remove the nut next time
John
I want to die peacefully in my sleep like my grandfather, not screaming
in terror like his passengers.
Legman is offline
Thruxton R, 4 months, 1600 miles and rusty spokes Luegolover Club Cafe' 52 03-23-2017 07:36 PM
Finally! A Cure for Rusty Nut Syndrome! Cal30M1 Classic, Vintage & Veteran 13 05-18-2016 08:22 PM
Rusty Spark Plug Broadsman Hinckley Classic Triples 4 12-19-2015 03:01 AM
Rusty Petrol tank Q1 wol Classic, Vintage & Veteran 5 03-12-2015 07:46 AM
Rusty bits after 4 weeks Dickie2679 Air Cooled Twins Talk 14 04-08-2006 11:30 AM
