Battery or Stator issue??? - Triumph Forum: Triumph Rat Motorcycle Forums
 5Likes
post #1 of 50 (permalink) Old 05-07-2019, 11:54 AM Thread Starter
haharel's Avatar
2009 speed triple steel tank.
10am - Bike started just fine. went on an hour ride. Then went to the gym.
12:30pm - bike started no issues. Drove to a nice spot to take a pic of the sexy Speed triple...
1:00pm - Slow crank. Lights and cluster bright. no start.
1:30pm - had road side jump me from his cage ( portable jumper wasnt doing enough)
1:45pm - rode her around for 15 minutes. got home. wouldnt start again....
From there I connected my battery tender jr. for a little bit until it could start again. Then connected to TUNEECU.
Bike not running - battery at 12.9v
Bike running at idle after 10 seconds - battery at 13.2v. then after a little bit up to 14v.
Bike Rev at 4k - battery drops down to 13v. then back to 14v at idle.
With the voltage going up and down, I automatically assumed that everything was alright at this point. Left the battery tender on over night. Drove her to work the next day. Started up just fine in the morning. Once I shut her off at work, wouldnt start again....
any thoughts???
haharel is offline
post #2 of 50 (permalink) Old 05-07-2019, 02:14 PM
Main Motorcycle: 2010 15th Anniversary S3!
S4Bill's Avatar
Other Motorcycle: 1999 Harley Fat Boy
any thoughts???
Connect a Volt meter on the Battery at start up and see what the Battery voltage drops to?
Whats the Battery Voltage after charged then it sits with no charger?
Sounds like your Battery is going, sometimes they go quickly other times not...
IMHO
haharel likes this.
S4Bill is online now
post #3 of 50 (permalink) Old 05-07-2019, 02:25 PM Thread Starter
haharel's Avatar
Unfortunately I do not have a meter. My only available tool to see the battery voltage is through tuneECU.
I did remove the battery tender from the bike last evening around 5pm (fully charged). I started her up this morning around 8am no problem. Unfortunately I was not able to check the actual voltage as I was on the way to work.
haharel is offline
post #4 of 50 (permalink) Old 05-07-2019, 02:34 PM
Main Motorcycle: 2015 KTM 1290 SDR
Ferris's Avatar
OEM Yuasa YTX12-BS, cheaper lead-acid or lithium battery?
Location? Helps if we know whether we're talking Autumn/Spring...ambient temperature etc.
Ferris is online now
post #5 of 50 (permalink) Old 05-07-2019, 02:38 PM Thread Starter
haharel's Avatar
lol perfect timing, i actually just purchased this one to rule out the battery issue - Yuasa Fresh Pack Maintenance-Free AGM Battery (YTX12-BS)
I live in Las Vegas Nevada. Current weather is high 80 low 60
haharel is offline
post #6 of 50 (permalink) Old 05-07-2019, 02:42 PM Thread Starter
haharel's Avatar
oh and to actually answer your question, It does look like a cheap battery. I purchased the bike about a month ago. Previous owner stated it was new as well. Wires look intact and no corrosion
haharel is offline
post #7 of 50 (permalink) Old 05-07-2019, 02:53 PM
Main Motorcycle: 2017 Speed Triple S
Speedy Russ's Avatar
Other Motorcycle: 2006 SV1000S
Extra Motorcycle: 2005 Crashed SV1000S
Long shot but does rotating the bars back and forth have any effect when trying to start it?
You got loud pipes, but you ain't sayin' nothing!
Speedy Russ is online now
post #8 of 50 (permalink) Old 05-07-2019, 02:56 PM Thread Starter
haharel's Avatar
Umm wouldnt think so? I attempted to push start the motorcycle when it had originally died. Was unsuccessful lol.
haharel is offline
post #9 of 50 (permalink) Old 05-07-2019, 03:11 PM
Ferris's Avatar
Glad you got a new Yuasa. I always believed the 2005-2010 had an underpowered battery from factory so need all the help they can get. Hence earlier and later bikes run a larger YTX14-BS.
haharel likes this.
post #10 of 50 (permalink) Old 05-07-2019, 03:15 PM Thread Starter
haharel's Avatar
Thanks Ferris. I hope this fixes the issue. She has been running so great since I purchased her last month.
The fact that the battery voltage did fluctuate while being connected to tuneecu gives me SOME peace of mind with the stator and RR.
haharel is offline
12V power cuts lilic24000 Classic, Vintage & Veteran 24 04-04-2019 03:41 PM
1970 t100s tiger runs fine for about 30 mins then sputters Pepperdog Classic, Vintage & Veteran 22 06-16-2018 05:21 PM
weak spark bluessss B33rslave Classic, Vintage & Veteran 20 06-16-2018 02:54 PM
Improved battery voltage monitor Forchetto Air Cooled Twins Technical Talk 17 04-30-2011 12:12 AM
Low Battery voltage causes ECU problems! Prubert Speed Triple Forum 0 02-12-2005 04:06 PM
