Leaking nipples... Brake nipples - Triumph Forum: Triumph Rat Motorcycle Forums
 4Likes
post #1 of 19 (permalink) Old 04-16-2019, 11:47 AM Thread Starter
Mashers's Avatar
After cleaning up my calipers I replaced my brake hoses with new HEL braided ones, but had a nightmare bleeding my front brakes...
Leaking nipples... Brake nipples-screenshot_20190416-163706_gallery_1555429082086.jpg
Leaking nipples... Brake nipples-screenshot_20190416-163657_gallery_1555429108806.jpg
I bought a vacuum pump and it just consistently sucked air into the system. I eventually found that the air was coming from between the threads of the bleed screws. I ended up doing it the old fashioned way and it worked fine. My brakes were great and super sensitive.
However, after the first ride I noticed fluid on the calipers. It turns out the nipples were leaking. I had torqued them up to 7nm as per the manual.
I decided to replace them but could only get mild steel ones at short notice...
Leaking nipples... Brake nipples-screenshot_20190416-163547_gallery_1555429291344.jpg
After swapping them out and going for a ride... The problem persists.
I did have to "break" the old nipples out when I did the first bleed. They were in very tight so I guess whoever did the brakes last has overdone it.
I've now tightened them up way more than recommended but still leaking around the threads.
Any suggestions? As I understand it it's not the thread that seals them so don't see how retapping will help...
Mashers is offline
post #2 of 19 (permalink) Old 04-16-2019, 01:40 PM Thread Starter
Mashers's Avatar
FT...?
Mashers is offline
post #3 of 19 (permalink) Old 04-16-2019, 02:20 PM
Main Motorcycle: 2017 Speed Triple S
Speedy Russ's Avatar
Other Motorcycle: 2006 SV1000S
Extra Motorcycle: 2005 Crashed SV1000S
I've heard of people using Teflon tape (a.k.a plumbers tape). Personally, I've never used it but it seems like a relatively harmless and inexpensive thing to try.
Bring out the gimp.
Speedy Russ is offline
post #4 of 19 (permalink) Old 04-16-2019, 03:03 PM
Supernova
DEcosse's Avatar
Originally Posted by Mashers View Post
... As I understand it it's not the thread that seals them so don't see how retapping will help...
That is correct - it is the tapered seat at the bottom that is the 'seal' - it leaks past the threads because it is first leaking past the actual seal.
Looking at your new nipples, it appears the taper is not exactly the same (well at least originals look more pointed and replacements rounded)
- I would get some 'better' nipples, or even re-try the originals
DEcosse is offline
post #5 of 19 (permalink) Old 04-16-2019, 04:56 PM
Main Motorcycle: 2018 Tiger 800 XRx Low
Other Motorcycle: 2013 Street Triple R
Extra Motorcycle: 2019 Z900RS Cafť
Are you sure it is not residual? I always get some sipping out after a bleed. I wipe it and watch if it will sip out again, it might do a tiny drip once more, and then stops. With oil, a drop looks like a lot.
Evangelos K is offline
post #6 of 19 (permalink) Old 04-16-2019, 05:10 PM
Main Motorcycle: Street Triple R
After installing nipples and re-torquing to spec, give them a good spray of brake cleaner, wipe down, and re-check.
I had nipples that didnít want to stop leaking. Thought I wasnít tightening enough even though it was set to spec. Turns out it was residual, as previously mentioned. Brake cleaner saved the day!
Sent from my iPhone using Tapatalk
rookie01 is offline
post #7 of 19 (permalink) Old 04-16-2019, 06:06 PM Thread Starter
Mashers's Avatar
As I understand it, it's not the threads that seal so thread lock or ptfe may help but isn't fixing the issue.
Mashers is offline
post #8 of 19 (permalink) Old 04-16-2019, 06:08 PM Thread Starter
Mashers's Avatar
Agreed. I noticed the angles and diameter was different so I replaced with the old... No luck and the problem was still there (on all three brakes!)
Mashers is offline
post #9 of 19 (permalink) Old 04-16-2019, 06:10 PM Thread Starter
Mashers's Avatar
Definitely not residual. I could squeeze the brake and hold it for 10 seconds and a drip would appear around the thread.
Mashers is offline
post #10 of 19 (permalink) Old 04-16-2019, 06:23 PM Thread Starter
Mashers's Avatar
I think I fixed the problem tonight. I drained the system, cleaned the bleed holes and took a look inside. Each of the calipers had a slightly misshapen bleed hole under the screw. It didn't make sense to me that the cone of the nipple could sit in a hole that was oval or had ridges... I should have taken a photo really.
So I got the drill out with a bit just the right size and rounded off the holes in the calipers. I've cleaned the filings out, filled and bled the system and it doesn't appear to be leaking now. 👍
I went back to using the new nipples again because my "FT" attempt ruined them 😳
Rampant likes this.
Mashers is offline
Rounded brake pad retaining pin Lewishamilton Water Cooled Twins Talk 2 03-11-2019 07:32 AM
Leaking brake fluid reservoir on the Blue Ride Parkway... jkrobin Air Cooled Twins Talk 8 07-06-2016 11:00 AM
Leaking Brake Hose Demonic Air Cooled Twins Technical Talk 4 08-01-2012 05:30 PM
Bleedin Brake Nipples ! SkyeT140 Classic, Vintage & Veteran 0 09-04-2010 03:27 PM
Speed Bleeder Nipples for Easy Brake Bleeding, What size do I want? robnobrakes Air Cooled Twins Technical Talk 4 01-29-2007 02:25 AM
