Leak from dry break connector - Triumph Forum: Triumph Rat Motorcycle Forums
 9Likes
post #1 of 30 (permalink) Old 04-04-2019, 05:52 PM Thread Starter
Main Motorcycle: 2000 Triumph 955i S3
Rayvin's Avatar
Pulled my tank off today--about time, I've had my S3 for 3 days already--and when I disconnected the lower fuel hose from the dry break, a small stream of gas continued to come out of it. No leak when I reconnect the hose to it. Is this probably a broken dry break connector? Don't want to throw money at it if there are other reason for it not to shut off completely when the hose is pulled.
Thanks.
Rayvin is offline
post #2 of 30 (permalink) Old 04-04-2019, 06:07 PM
Supernova
DEcosse's Avatar
https://www.triumphrat.net/daytona-d...placement.html
Yes, it will only be an issue when you are doing maintenance and have to disconnect that hose.
If it starts leaking while connected it would be the o-ring* on the male hose connector
(which often happens - those o-rings are very easy to nick during re-install - put some vaseline on them and depress the latch to insert rather than just clicking them in)
*Unless the fitting itself fracture - honestly this is an event waiting to happen - the OEM nylon ones get very brittle after the years and if you look at it wrong it will snap off) as indeed it will when you go to remove it )
Given it's already leaking anyway, I would suggest this would be a good project to schedule and just install the metal ones.
DEcosse is online now
post #3 of 30 (permalink) Old 04-04-2019, 06:16 PM Thread Starter
Rayvin's Avatar
DE--whatever you aren't being paid to moderate this forum should be doubled. Thanks again for the quick reply and good advice. Shopping for the metal ones now.
Found them on ebay for less than the plastic oem ones. They wanted 31 a piece, I offered 40 for 2 of them. Stock ones are 33 each.
Rayvin is offline
post #4 of 30 (permalink) Old 04-04-2019, 07:54 PM
Supernova
DEcosse's Avatar
Just be sure the Ebay ones are BSPT - often you will see NPT ones that look virtually identical (and the thread is not hugely different - but enough)
If they paid me double, I still wouldn't have enough to buy the water that goes to make a cup of coffee
post #5 of 30 (permalink) Old 04-04-2019, 08:05 PM
Supernova
DEcosse's Avatar
p.s. only $13 ea at FreshWaterSystems (see thread) - add shipping but doubt if it would be $14 ........
post #6 of 30 (permalink) Old 04-04-2019, 10:34 PM Thread Starter
Rayvin's Avatar
The manufacturer is CPC. https://www.ebay.com/itm/18330988538...torefresh=true
I went with ebay, 2 for $50 incl. shipping. Just about the same as getting them from quickcouplings, which were $18 each plus 11 bucks shipping. I've read I should use RTV on the threads when installing?
Rayvin is offline
post #7 of 30 (permalink) Old 04-10-2019, 02:51 PM Thread Starter
Rayvin's Avatar
So I tried the hot screwdriver method, but whatever they used on those nylon threads is strong stuff. Here's where I'm at now. USPS lost the package with the break connectors, says it was delivered but not here, so I probably have some time to get these the remnants of those connectors out. I'm guessing getting the right tap would be my next step.
Rayvin is offline
post #8 of 30 (permalink) Old 04-10-2019, 02:56 PM
Supernova
DEcosse's Avatar
Originally Posted by Rayvin View Post
.... I've read I should use RTV on the threads when installing?
Not sure where you read that!
You can use a proper gasoline-resistant thread locker, but PTFE tape is my choice.
Have you tried an EZ-out?
Even if you get a Tap, you're going to have to get a LOT more material out before you can use it
Rayvin likes this.
post #9 of 30 (permalink) Old 04-14-2019, 04:33 PM Thread Starter
Rayvin's Avatar
The easy out didn't move them, so I took a soldering iron and melted as much of the plastic as I could. Now I'm ordering a 1/4" bsp die, but want to make sure it is the right one. Will this do the trick?
https://www.amazon.com/IRWIN-1912ZR-...gateway&sr=8-3
Thanks!
Rayvin is offline
post #10 of 30 (permalink) Old 04-14-2019, 06:12 PM
Main Motorcycle: '00 Speed Triple 955i
Rampant's Avatar
Yup that looks like the right one
Rayvin likes this.
Rampant is offline
Fuel leak - its the plastic white return connector ta3one Sprint Forum 23 08-06-2014 04:07 PM
Oil Leak cacinc77 Air Cooled Twins Technical Talk 0 05-29-2014 08:33 AM
Yet another oil leak on my new Thruxton. Can't seem to find this one. MKE BG Thrux Air Cooled Twins Technical Talk 35 07-26-2013 04:14 PM
Odd Fuel Leak 3banger Sprint Forum 6 12-03-2007 10:46 AM
Broken Dry Break plug on fuel tank... MarioG Speed Triple Forum 4 05-15-2007 02:17 AM
